[Qgis-user] polygon fills from different shapefiles
Thayer Young thayeray at yahoo.com
Tue Jun 21 14:09:26 PDT 2022
 to quote my favorite movie: "Rock and Roll, hello Cleveland!"
-Thayer
    On Tuesday, June 21, 2022 at 04:39:28 PM EDT, Sebastian Gutwein <bas at rdgland.com> wrote:
 And even easier is to put them all in a group then copy the style from one layer and paste it onto the group. This will apply the style to all layers in the group.
On Tue, Jun 21, 2022 at 3:22 PM Thayer Young via Qgis-user <qgis-user at lists.osgeo.org> wrote:
 A method that is a little easier than saving out the style file, is that you can just right click on the layer that you styled, then third from the bottom in the menu select:   Styles: Copy Style: All Style CategoriesAnd then you can paste the style to the rest of your layers using:  Styles: Paste Style: All Style Categories
-Thayer
    On Tuesday, June 21, 2022 at 03:00:36 PM EDT, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
i have four different geologic maps that i have imported as shapefiles.
The files have filled polygons that have the name of the geologic formation
in the attribute tables.  i would like to have a common colour for each
polygon of identical age/name for all the map sheets.  Each map sheet has a
similar list of formations, but some of the formations are different for
each map sheet.
What is the most efficient way to make the identically named polygons
displayed with the same colour?  Should i add a column in each attribute
table and put a formation code in for each one manually or can i add an RGB
colour for each formation in the attribute table? or, do i need to
categorize and  classify these in the layer properties table after i have
added formation code in the attribute table?
i hope that my question is clear.
Byron Veilleux, MSc. P.Geo
Conjugate Geologic Services Limited
Calgary, Alberta Canada
byron at conjugategeo.com
Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220620/c8b38539/attachment-0001.htm>
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
___________________________
Sebastian "Bas* " Gutwein*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
Look close, think big, make change.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220621/40071e46/attachment.htm>
