[Qgis-user] how to simplify polygons without loosing too much information
Benjamin Ducke benducke at fastmail.fm
Mon Jun 27 08:16:06 PDT 2022
Note that there is also "v.generalize" (if you have the GRASS provider
activated in Processing). It implements many additional algorithms and
provides a comprehensive Help page.
It would be interesting to know which algorithm (and parameters) gave
you the best results!
Best,
Ben
On 27/06/2022 16:58, Johannes Kröger (WhereGroup) via Qgis-user wrote:
> Hey Michael,
> the algorithms involved are Douglas-Peucker and Visvalingam. With those
> terms you might find some nice explanations and guidance online. Some
> quick links:
> - http://bl.ocks.org/msbarry/9152218
> - https://dulldrums.github.io/polygon-reduction-algorithms-demo/
> - https://ignf.github.io/CartAGen/docs/algorithms/line/visvalingam.html
> For your use case (keeping the overall shape) I would try Visvalingam
> first as that is pretty much its goal too.
> Cheers, Hannes
> Am 27.06.22 um 16:52 schrieb Michael.Dodd via Qgis-user:
>> I know there are various simplify tools in qgis but perhaps I don’t
>> understand how to use them best. I want to simplify i.e. reduce the
>> number of nodes in a polygon without changing the overall shape too
>> much for country or similar outlines.  When I have tried this the
>> simplify tends to chop off bits that a human doing a manual
>> simplification would not, in some areas the simplification could loose
>> loads of nodes whereas in other areas it needs to keep more of them or
>> the overall shape will be greatly changed. Is there anyway round this
>> or am I asking for something that is not logical?
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Johannes Kröger / GIS-Entwickler/-Berater
> Schon gewusst?
> In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
> und berichten aus unserem Experten-Alltag:
> https://wheregroup.com/blog/
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
