[Qgis-user] Something in the shapefile (???) - RE: Did KML Tools functionality change for everybody else or just me?
Jeff Sonnentag
jsonnentag at llenviroinc.com
Tue Mar 1 10:59:53 PST 2022
Well, since I knew I had just exported something fine last week I went and checked that KMZ to be sure and also exported it again and that worked fine.
So QGIS was closed, started again, and the only thing opened was the specific shapefile and the style always used was created again by the last column's values and transparency of all the created categories was set to 50%. But, once again exporting to KMZ doesn't work from that shapefile. I tried exploding all the pieces and exporting from the temporary file (geometry of Polygon [Polygon] rather than the MultiPolygon that the original is) and that didn't work either.
Anyway, I put a copy of the set of shapefiles in here and if somebody can figure out what is wrong with it it would be nice to know. Might help some other people in the future too or enable a modification to the plugin to detect whatever is messing things up. :D
https://www.dropbox.com/sh/k6mai4wkpd6taib/AAAfi6I884t4c_mBb55EvPila?dl=1
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Jeff Sonnentag
Sent: Tuesday, March 1, 2022 10:11 AM
To: qgis-user <qgis-user at lists.osgeo.org>; adenaculture at gmail.com
Subject: [Qgis-user] Did KML Tools functionality change for everybody else or just me?
I'm positive KML Tools worked perfectly fine before in exporting the Symbology style (some Categories of various colors and transparency) the same as visible in QGIS. But now everything comes out one style/color rather than the ones they are supposed to be. I still have the box checked for "Export style for single, categorized, and graduated symbols [optional]" and also installed the latest version (since I saw there was another one). Restarted QGIS (3.22.24) and it still only puts out a single style rather than all the various colors visible in the shapefile in QGIS.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220301/3058a071/attachment.html>
