[Qgis-user] Something in the shapefile (???) - RE: Did KML Tools functionality change for everybody else or just me?
C Hamilton
adenaculture at gmail.com
Tue Mar 1 11:40:01 PST 2022
Jeff,
I can replicate the problem. I have an idea about what may be wrong. I will
get this working, but I am not sure when. Hopefully, this week, but if not
probably next week.
Thanks for bringing this to my attention.
Calvin
On Tue, Mar 1, 2022 at 6:59 PM Jeff Sonnentag <jsonnentag at llenviroinc.com>
wrote:
> Well, since I knew I had just exported something fine last week I went and
> checked that KMZ to be sure and also exported it again and that worked fine.
> So QGIS was closed, started again, and the only thing opened was the
> specific shapefile and the style always used was created again by the last
> column’s values and transparency of all the created categories was set to
> 50%. But, once again exporting to KMZ doesn’t work from that shapefile. I
> tried exploding all the pieces and exporting from the temporary file
> (geometry of Polygon [Polygon] rather than the MultiPolygon that the
> original is) and that didn’t work either.
> Anyway, I put a copy of the set of shapefiles in here and if somebody can
> figure out what is wrong with it it would be nice to know. Might help some
> other people in the future too or enable a modification to the plugin to
> detect whatever is messing things up. :D
> https://www.dropbox.com/sh/k6mai4wkpd6taib/AAAfi6I884t4c_mBb55EvPila?dl=1
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> * On Behalf Of *Jeff
> Sonnentag
> *Sent:* Tuesday, March 1, 2022 10:11 AM
> *To:* qgis-user <qgis-user at lists.osgeo.org>; adenaculture at gmail.com
> *Subject:* [Qgis-user] Did KML Tools functionality change for everybody
> else or just me?
> I’m positive KML Tools worked perfectly fine before in exporting the
> Symbology style (some Categories of various colors and transparency) the
> same as visible in QGIS. But now everything comes out one style/color
> rather than the ones they are supposed to be. I still have the box checked
> for “Export style for single, categorized, and graduated symbols
> [optional]” and also installed the latest version (since I saw there was
> another one). Restarted QGIS (3.22.24) and it still only puts out a single
> style rather than all the various colors visible in the shapefile in QGIS.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220301/851d069c/attachment-0001.html>
