[Qgis-user] Is it possible to import Arcgis Pro map to QGIS?
    Stefan Giese (WhereGroup)
    stefan.giese at wheregroup.com
    Tue Mar  1 23:19:17 PST 2022
Hello,
we have provided a free open source Tool "MapQonverter" which can write
QGIS project files from ArcMap project files. The only thing is, the
tool is an ArcMap Toolbox, so ArcMap will be needed to use it 😮 - that
is the main difference to SLYR from NorthRoad which can read mxd files -
and ArcGis Pro files - directly into QGIS.
Our tool is available here: https://github.com/WhereGroup/mapqonverter
Best regards
Stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSSGIS Konferenz
09.-12. März 2022 online
https://www.fossgis-konferenz.de/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 02.03.2022 um 01:35 schrieb krishna Ayyala:
> An extension to this question. SLYR is not free. By any chance, are
> you aware of any open source plugin or tool to accomplish this task?
> Regards.
> On Tue, Mar 1, 2022 at 4:27 PM krishna Ayyala
> <ayyalakrishna at gmail.com> wrote:
>     Nyall,
>     Thanks a lot for the information.
>     Regards.
>     On Tue, Mar 1, 2022 at 3:19 PM Nyall Dawson
>     <nyall.dawson at gmail.com> wrote:
>         On Wed, 2 Mar 2022 at 08:13, Alexandre Neto
>         <senhor.neto at gmail.com> wrote:
>         > ArcGIS pro map is a binary (non-human-readable) proprietary
>         format. Which means that, apart from ESRI, no one knows how to
>         read and write those files.
>         >  So, no. You can't.
>         Actually -- just to clarify. SLYR (https://north-road.com/slyr/)
>         currently has support for reading ArcMap documents (including
>         lyr/mxd/etc) and converting to QGIS, and is shortly to receive
>         support
>         for conversion of ArcGIS Pro lyrx/aprx documents too!
>         Nyall
>         > A terça, 1/03/2022, 21:49, krishna Ayyala
>         <ayyalakrishna at gmail.com> escreveu:
>         >> Hello,
>         >> I have a Arcgis pro map saved with (.mapx ) extension.Is it
>         possible to bring this map into QGIS without losing the symbology?
>         >> Regards.
>         >> _______________________________________________
>         >> Qgis-user mailing list
>         >> Qgis-user at lists.osgeo.org
>         >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220302/7b73d526/attachment.html>
