[Qgis-user] Is it possible to import Arcgis Pro map to QGIS?
    krishna Ayyala
    ayyalakrishna at gmail.com
    Wed Mar  2 10:48:49 PST 2022
Stefan,
Thanks for the reply. I have added the "Mapqonverter.tbx" to the arcmap
tool box. In the tool box there are two script files. 1.ArcMap Project to
QGIS Project and 2. Style Gallery Export. The script file "ArcMap Project
to QGIS Project " is blank i.e. there is no script in it. So, I copied the
script from "mapqonverter.py" from github link and pasted. When I ran the
tool, I get the following error message.
[image: image.png]
On Wed, Mar 2, 2022 at 12:19 AM Stefan Giese (WhereGroup) <
stefan.giese at wheregroup.com> wrote:
> Hello,
> we have provided a free open source Tool "MapQonverter" which can write
> QGIS project files from ArcMap project files. The only thing is, the tool
> is an ArcMap Toolbox, so ArcMap will be needed to use it 😮 - that is the
> main difference to SLYR from NorthRoad which can read mxd files - and
> ArcGis Pro files - directly into QGIS.
> Our tool is available here: https://github.com/WhereGroup/mapqonverter
> Best regards
> Stefan
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> FOSSGIS Konferenz
> 09.-12. März 2022 onlinehttps://www.fossgis-konferenz.de/
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Tel.: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Am 02.03.2022 um 01:35 schrieb krishna Ayyala:
> An extension to this question. SLYR is not free. By any chance, are you
> aware of any open source plugin or tool to accomplish this task?
> Regards.
> On Tue, Mar 1, 2022 at 4:27 PM krishna Ayyala <ayyalakrishna at gmail.com>
> wrote:
>> Nyall,
>> Thanks a lot for the information.
>> Regards.
>> On Tue, Mar 1, 2022 at 3:19 PM Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>>> On Wed, 2 Mar 2022 at 08:13, Alexandre Neto <senhor.neto at gmail.com>
>>> wrote:
>>> > ArcGIS pro map is a binary (non-human-readable) proprietary format.
>>> Which means that, apart from ESRI, no one knows how to read and write those
>>> files.
>>> >  So, no. You can't.
>>> Actually -- just to clarify. SLYR (https://north-road.com/slyr/)
>>> currently has support for reading ArcMap documents (including
>>> lyr/mxd/etc) and converting to QGIS, and is shortly to receive support
>>> for conversion of ArcGIS Pro lyrx/aprx documents too!
>>> Nyall
>>> > A terça, 1/03/2022, 21:49, krishna Ayyala <ayyalakrishna at gmail.com>
>>> escreveu:
>>> >> Hello,
>>> >> I have a Arcgis pro map saved with (.mapx ) extension.Is it possible
>>> to bring this map into QGIS without losing the symbology?
>>> >> Regards.
>>> >> _______________________________________________
>>> >> Qgis-user mailing list
>>> >> Qgis-user at lists.osgeo.org
>>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220302/7b512be4/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220302/7b512be4/attachment.png>
