[Qgis-user] Is it possible to import Arcgis Pro map to QGIS?
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Wed Mar 2 23:01:59 PST 2022
Krishna,
as you see in the error message, there is no module "comtypes" which
must be installed on your computer: https://pypi.org/project/comtypes/
Best regards
Stefan
Am 02.03.2022 um 19:48 schrieb krishna Ayyala:
> Stefan,
> Thanks for the reply. I have added the "Mapqonverter.tbx" to the
> arcmap tool box. In the tool box there are two script files. 1.ArcMap
> Project to QGIS Project and 2. Style Gallery Export. The script file
> "ArcMap Project to QGIS Project " is blank i.e. there is no script in
> it. So, I copied the script from "mapqonverter.py" from github link
> and pasted. When I ran the tool, I get the following error message.
> On Wed, Mar 2, 2022 at 12:19 AM Stefan Giese (WhereGroup)
> <stefan.giese at wheregroup.com> wrote:
> Hello,
> we have provided a free open source Tool "MapQonverter" which can
> write QGIS project files from ArcMap project files. The only thing
> is, the tool is an ArcMap Toolbox, so ArcMap will be needed to use
> it 😮 - that is the main difference to SLYR from NorthRoad which
> can read mxd files - and ArcGis Pro files - directly into QGIS.
> Our tool is available here: https://github.com/WhereGroup/mapqonverter
> Best regards
> Stefan
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> FOSSGIS Konferenz
> 09.-12. März 2022 online
> https://www.fossgis-konferenz.de/
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Tel.: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> www.wheregroup.com <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Am 02.03.2022 um 01:35 schrieb krishna Ayyala:
>> An extension to this question. SLYR is not free. By any chance,
>> are you aware of any open source plugin or tool to accomplish
>> this task?
>> Regards.
>> On Tue, Mar 1, 2022 at 4:27 PM krishna Ayyala
>> <ayyalakrishna at gmail.com> wrote:
>> Nyall,
>> Thanks a lot for the information.
>> Regards.
>> On Tue, Mar 1, 2022 at 3:19 PM Nyall Dawson
>> <nyall.dawson at gmail.com> wrote:
>> On Wed, 2 Mar 2022 at 08:13, Alexandre Neto
>> <senhor.neto at gmail.com> wrote:
>> > ArcGIS pro map is a binary (non-human-readable)
>> proprietary format. Which means that, apart from ESRI, no
>> one knows how to read and write those files.
>> > So, no. You can't.
>> Actually -- just to clarify. SLYR
>> (https://north-road.com/slyr/)
>> currently has support for reading ArcMap documents (including
>> lyr/mxd/etc) and converting to QGIS, and is shortly to
>> receive support
>> for conversion of ArcGIS Pro lyrx/aprx documents too!
>> Nyall
>> > A terça, 1/03/2022, 21:49, krishna Ayyala
>> <ayyalakrishna at gmail.com> escreveu:
>> >> Hello,
>> >> I have a Arcgis pro map saved with (.mapx )
>> extension.Is it possible to bring this map into QGIS
>> without losing the symbology?
>> >> Regards.
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> List info:
>> https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe:
>> > List info:
>> > Unsubscribe:
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Stefan Giese
FOSSGIS Konferenz
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/42836ca1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/42836ca1/attachment-0001.png>
