[Qgis-user] Displaying county attribute names in the layers column
Richard McDonnell
richard.mcdonnell at opw.ie
Tue Mar 1 23:42:03 PST 2022
Hi Mike,
Right click on the Layer, select Properties and go to Symbology. From there you should see, at the top, a drop down menu set to Single Symbol. You should change this to Categorize. Then under Value, set this to the Counties name field. Then click on Classify.
I hope that helps.
Regards,
Richard.
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
Sent: 02 March 2022 07:41
To: 'Mike Breiding - Morgantown WV' <epicroadtrips at gmail.com>
Subject: RE: [Qgis-user] Displaying county attribute names in the layers column
Hi Mike,
I hope that helps.
Regards,
Richard.
From: Mike Breiding - Morgantown WV <epicroadtrips at gmail.com<mailto:epicroadtrips at gmail.com>>
Sent: 01 March 2022 18:22
To: Richard McDonnell <richard.mcdonnell at opw.ie<mailto:richard.mcdonnell at opw.ie>>
Subject: Re: [Qgis-user] Displaying county attribute names in the layers column
On 3/1/2022 10:46 AM, Richard McDonnell wrote:
Hi, In your Styling, set it to Categorized and select the field which has your County Names.
Click Classify and you should get the full list of Counties. You can then modify your style to match your requirements. Regard’s, Richard.
Hi Richard,
I am using Hannover 3.16
When I highlight the layer and right click there is no "Styling" option available.
There is a "Styles" option which is opens a color wheel of sorts.
If I choose "Properties" I see nothing called "Styling" listed.
I am not sure what to look for next.
Thanks,
WV-Mike
p.s. You email went only to me, not the list so that is how I am replying.
FRM Data Management
https://gov.ie/opw
From: Qgis-user <qgis-user-bounces at lists.osgeo.org><mailto:qgis-user-bounces at lists.osgeo.org> On Behalf Of Mike Breiding - Morgantown WV
Sent: 01 March 2022 17:21
To: QGIS User List <Qgis-user at lists.osgeo.org><mailto:Qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Displaying county attribute names in the layers column
Greetings,
I have a state county outline layer in a project and wish to be able to see a list of the county names in the Layers column.
I looked through the options for the Layers Properties and also went through the menus but I saw nothing obvious.
How might I accomplish this?
Thanks,
WV-Mike
Mike Breiding
www.EpicRoadTrips.us<http://www.EpicRoadTrips.us>
Mike Breiding
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220302/4183f337/attachment-0001.html>
