[Qgis-user] shapefile import error
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Mar 3 14:42:38 PST 2022
> *David Witton*
> /Thu Mar 3 11:45:41 PST 2022/
> The .shx and .dbf files are there - This mix of files is the same as the
> QGIS training data that can be successfully imported.
Hi David,
could you copy the files of Shapefile layer from the external drive to a
local drive of your system and try to import it in QGIS? Does it result
valid or invalid?
If it is invalid also from the local drive, could you share the files
(zipped) so it is possible to check them?
Regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/44d4a623/attachment.html>
