[Qgis-user] QGIS 3.22-4: wrong label placement in print composer
Uwe Fischer
gisfisch at t-online.de
Fri Mar 25 00:47:34 PDT 2022
Hello,
shame on me I had set the wrong unit for label offset (millimeters) which
causes the labels to shift when the map scale changes. Different scale in
the print composer compared to map view -> different label position. My
fault. When the unit is set to map units, it works fine. Sorry again.
Have a nice weekend, UF.
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Uwe
Fischer via Qgis-user
Gesendet: Donnerstag, 24. März 2022 11:55
An: qgis-user <qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] QGIS 3.22-4: wrong label placement in print composer
Hello list,
more problems with 3.22-4: I have a point layer with labels, which must be
placed Offset from point on the top-right, with additional fixed xy offset
values. In the QGIS map view, everything is ok. In the print composer, the
labels are suddenly placed at bottom right, which is not acceptable in this
case. Exact same thing has been working fine in 3.18.
Time to go back to 3.18 or is there a solution in 3.22-5?? Or in 3.24?
Where can I read details about improvements from 3.22-4 to 3.22-5? On the
web, theres only notes about 3.22 change log.
Does column sorting work now?
Thank you and best regards, Uwe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220325/d166149e/attachment.html>
An embedded and charset-unspecified text was scrubbed...
Name: Unbenannte Anlage 00070.txt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220325/d166149e/attachment.txt>
