[Qgis-user] Rendering of Raster image in Map Layout
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Wed May  4 09:45:08 PDT 2022
You can set the map output resolution. Set to 300dpi or more.
https://docs.qgis.org/3.4/en/docs/training_manual/map_composer/map_composer.html
See if that works.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 4 mai 2022 à 08:17, Bibek Rana via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Dear Sir/Madam,
> I am currently using QGIS 3.22 (long term release).
> I have added a topographic map (geotiff file) to the QGIS map canvas with details in the picture below.
> <image.png>
> The map was rendering very fine in the map canvas, i.e. i can zoom it finely to maximum level.
> Then I created a map layout in print composer and rendered the map in map layout in A3 size.
> However, the map looked very blurry in the layout when I tried to zoom in the layout in the print composer.
> Then I tried to export the map to PDF anf JPEG format. But the resolution of the Topo Map (Raster image) was very poor, blurry and pixelated.
> So, it would be really helpful if you could provide me with the solution to this problem.
> Regards,
> Bibek Bikram Rana
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220504/0a0794c7/attachment.htm>
