[Qgis-user] ReportLab integration into QGIS returns error message "no module named reportlab"
    Richard Duivenvoorde
    rdmailings at duif.net
    Mon May  9 00:30:55 PDT 2022
Hi Julio,
That is probably because QGIS does not use your system Python, but it's own installed version, so instlaling it in your globabl one does not make it available for QGIS.
I googled (qgis pip install) this one for you:
https://landscapearchaeology.org/2018/installing-python-packages-in-qgis-3-for-windows/
Regards,
On 5/9/22 04:52, julio cesar oliveira via Qgis-user wrote:
> Dears,
> I want to use ReportLab in my own plugin which I have written for QGIS.
> I have installed ReportLab for the python versions 3.10.
> The package is respectively installed into the site-packages folder (e.g. C:\Users\olive\AppData\Local\Programs\Python\Python310\Lib\site-packages\reportLab).
> If I want to use the tool in my plugin (from reportlab.pdfgen import canvas), the plugin returns the error "ImportError: no module named reportLab".
> C:\PyQgis\cav> pip install reportlab
> Requirement already satisfied: reportlab in c:\users\olive\appdata\local\programs\python\python310\lib\site-packages (3.6.9)
> Requirement already satisfied: pillow>=4.0.0 in c:\users\olive\appdata\local\programs\python\python310\lib\site-packages (from reportlab) (9.1.0)
> Do you have any other suggestions or ideas?
> Thanks
> Qgis-user mailing list
