[Qgis-user] ReportLab integration into QGIS returns error message "no module named reportlab"
Andrea Giudiceandrea
andreaerdna at libero.it
Mon May 9 01:32:47 PDT 2022
> *Richard Duivenvoorde*rdmailings at duif.net
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20ReportLab%20integration%20into%20QGIS%20returns%20error%0A%20message%20%22no%20module%20named%20reportlab%22&In-Reply-To=%3C533c2b83-6bef-3f60-8564-fe6b9c4a79db%40duif.net%3E>
> /Mon May 9 00:30:55 PDT 2022/
> I googled (qgis pip install) this one for you:
> https://landscapearchaeology.org/2018/installing-python-packages-in-qgis-3-for-windows/
That tutorial is a little bit outdated, since the "py3_env" command is
no longer part of the current OSGeo4W shell command set (and it is not
needed any more).
Just using the normal "pip install reportlab" command in the OSGeo4W
shell, as already pointed out by Ludwig Kniprath, let it possible to
install the reportlab Python module in order to be used in QGIS.
Regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220509/d5d633c1/attachment.htm>
