[Qgis-user] ReportLab integration into QGIS returns error message "no module named reportlab"
julio cesar oliveira
oliveirajc1 at gmail.com
Mon May 9 05:23:51 PDT 2022
Dears,
The installation of reportlab by the OSGeo4W shell worked.
Thanks
Em seg., 9 de mai. de 2022 às 05:33, Andrea Giudiceandrea via Qgis-user <
qgis-user at lists.osgeo.org> escreveu:
> *Richard Duivenvoorde* rdmailings at duif.net
> <qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20ReportLab%20integration%20into%20QGIS%20returns%20error%0A%20message%20%22no%20module%20named%20reportlab%22&In-Reply-To=%3C533c2b83-6bef-3f60-8564-fe6b9c4a79db%40duif.net%3E>
> *Mon May 9 00:30:55 PDT 2022*
> I googled (qgis pip install) this one for you:https://landscapearchaeology.org/2018/installing-python-packages-in-qgis-3-for-windows/
> That tutorial is a little bit outdated, since the "py3_env" command is no
> longer part of the current OSGeo4W shell command set (and it is not needed
> any more).
> Just using the normal "pip install reportlab" command in the OSGeo4W
> shell, as already pointed out by Ludwig Kniprath, let it possible to
> install the reportlab Python module in order to be used in QGIS.
> Regards.
> Andrea
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220509/da6ca82e/attachment.htm>
