[Qgis-user] OTB8.0.1-Learning-TrainImagesClassifier
Julien Cabieces julien.cabieces at oslandia.com
Mon May 9 00:25:11 PDT 2022
OTB 8.0 is not compatible with QGIS 3.16, you should use the 3.22 which
is the current LTR and which is compatible with OTB 8.0. Take a look at
the compatibility matrix:
https://www.orfeo-toolbox.org/CookBook/QGISInterface.html#compatibility-between-qgis-and-otb-versions
Regards,
Julien
> Good afternoon!
> When i use the OTB8.0.1-Learning-TrainImagesClassifier in area "Input
> Vector Data List" i have the message: "could not load selected table/layer.
> Dependent field cannot be filled".
> So, how can i fix this problem?
> I think the problem is in version 8.0.1
> I use Qgis 3.16.
> Qgis-user mailing list
