[Qgis-user] OTB8.0.1-Learning-TrainImagesClassifier
Alex Bley
alexbhossu2 at gmail.com
Mon May 9 16:28:31 PDT 2022
Thank you very much Julien
Regards,
Alex
Em seg., 9 de mai. de 2022 às 04:25, Julien Cabieces <
julien.cabieces at oslandia.com> escreveu:
> Hi,
> OTB 8.0 is not compatible with QGIS 3.16, you should use the 3.22 which
> is the current LTR and which is compatible with OTB 8.0. Take a look at
> the compatibility matrix:
> https://www.orfeo-toolbox.org/CookBook/QGISInterface.html#compatibility-between-qgis-and-otb-versions
> Regards,
> Julien
> > Good afternoon!
> > When i use the OTB8.0.1-Learning-TrainImagesClassifier in area "Input
> > Vector Data List" i have the message: "could not load selected
> table/layer.
> > Dependent field cannot be filled".
> > So, how can i fix this problem?
> > I think the problem is in version 8.0.1
> > I use Qgis 3.16.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220509/a1020429/attachment.htm>
