[Qgis-user] Tweaking an Atlas
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue May 10 20:18:51 PDT 2022
Hi Alexandre,
In the layout, under Item Properties/Rendering, I was able to change the
overview map opacity using IF (@atlas_featurenumber = '1','100','0').
Is there a better method?
Thanks everyone for the tips, I am finally figuring this out slowly.
Nicolas
On 2022-05-10 5:07 p.m., Alexandre Neto wrote:
> All items in the layout have a render item in outputs option. It's
> data-defined. So you can put a expression like if @atlas_page in
> (3,6,9,12)
> Alexandre Neto
> A terça, 10/05/2022, 21:06, Alexis R.L. via Qgis-user
> <qgis-user at lists.osgeo.org> escreveu:
> You could use the Data-defined variables to move elements in and
> out of the page layout depending on the atlas page name/number.
> Alex
> Le mar. 10 mai 2022 à 13:58, Nicolas Cadieux via Qgis-user
> <qgis-user at lists.osgeo.org> a écrit :
> Hi,
> I have a series of map that could work well this an Atlas but
> I would
> need to add thing like Zoom in or Overview maps on some
> specific pages
> only. Can we add objects like new maps on specific pages of
> an Atlas?
> If not, is there a function or way to go from Atlas page 2 ->
> New
> layout? I figure the only way to do this is to turn on the Atlas
> preview, go to the selected preview, turn the Atlas preview
> off and the
> save as a new layout? Is there a better way?
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Qgis-user mailing list
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220510/1fd0deaa/attachment.htm>
