[Qgis-user] Tweaking an Atlas
Alexandre Neto
senhor.neto at gmail.com
Tue May 10 22:56:20 PDT 2022
Hi!
Sorry, I mislead you with a wrong name
It's the "Exclude item from exports"
https://docs.qgis.org/3.22/en/docs/user_manual/print_composer/composer_items/composer_items_options.html#rendering-mode
The data-defined expression expects a true or false (1 or 0) so you can use
whatever you prefer to check that out. In the limit, you can add an extra
boolean column to you atlas layer called "exclude_overview" and fill in a
yes for the features you don't want to show a overview. The use that column
in the data-defined properties of the "exclude item from export"
Alexandre Neto
User Support
www.qcooperative.net
A quarta, 11/05/2022, 04:18, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
escreveu:
> Hi Alexandre,
> In the layout, under Item Properties/Rendering, I was able to change the
> overview map opacity using IF (@atlas_featurenumber = '1','100','0'). Is
> there a better method?
> Thanks everyone for the tips, I am finally figuring this out slowly.
> Nicolas
> On 2022-05-10 5:07 p.m., Alexandre Neto wrote:
> All items in the layout have a render item in outputs option. It's
> data-defined. So you can put a expression like if @atlas_page in (3,6,9,12)
> Alexandre Neto
> A terça, 10/05/2022, 21:06, Alexis R.L. via Qgis-user <
> qgis-user at lists.osgeo.org> escreveu:
>> You could use the Data-defined variables to move elements in and out of
>> the page layout depending on the atlas page name/number.
>> Alex
>> Le mar. 10 mai 2022 à 13:58, Nicolas Cadieux via Qgis-user <
>> qgis-user at lists.osgeo.org> a écrit :
>>> Hi,
>>> I have a series of map that could work well this an Atlas but I would
>>> need to add thing like Zoom in or Overview maps on some specific pages
>>> only. Can we add objects like new maps on specific pages of an Atlas?
>>> If not, is there a function or way to go from Atlas page 2 -> New
>>> layout? I figure the only way to do this is to turn on the Atlas
>>> preview, go to the selected preview, turn the Atlas preview off and the
>>> save as a new layout? Is there a better way?
>>> Nicolas Cadieux
>>> https://gitlab.com/njacadieux
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Nicolas Cadieuxhttps://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220511/b6c099a5/attachment-0001.htm>
