[Qgis-user] New objectid numbers after using DIFFERENCE
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed May 11 08:03:14 PDT 2022
If you are using a geopackage, you are probably getting a message that
the file cannot be saved as geopackage requires a unique id field. You
can open the field calculator and update the field using $id for the
unique ID field. If you delete this unique ID field, it will be
recreated correctly if you delete the field and save the file (if you
save in a geopackage file format). (I guess this also has the potential
to corrupt the file so this would be a last chance option). You can
also use the autoincremental field function found in processing if you
don't have a unique id field.
Nicolas
On 2022-05-11 5:32 a.m., Keith Trees via Qgis-user wrote:
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows
> Hi All
> I have two vector polygon layers, soil and native vegetation
> respectively. I used vector-geoprocessing tools-Difference to get the
> output of the soils that had no native vegetation.
> The problem is that there are now multiple polygons that share the
> same objectid as they are remnants of an original polygon. This is
> repeated through the layer.
> How can I renumber the objectids so each polygon has a unique value?
> I need to be able to identify each polygon and also calculate its area.
> Regards
> Keith
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220511/9767adf6/attachment.htm>
