[Qgis-user] Attribute table issue
Lester Anderson
arctica1963 at gmail.com
Thu May 12 22:59:03 PDT 2022
Hello all,
I had to apply a "fix geometries" on a shapefile which worked fine.
However, it appears to move the fixed elements to the top of the table and
as a result the sequence is out of order, e.g.:
[image: image.png]
Is it possible to put things back in the correct order (by ID); 12 and 13
should be the last rows ?
Thanks
Lester
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220513/146e45c4/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220513/146e45c4/attachment-0001.png>
