[Qgis-user] Attribute table issue
Richard Duivenvoorde
rdmailings at duif.net
Thu May 12 23:21:31 PDT 2022
The attribute table is a 'view' on your data. The (technical) order of your data is not important is it?
Anyway: you can click on the ID column to make the attribute table sort on ID column (or click again to do a reverse sort)
HTH
Regards,
On 5/13/22 07:59, Lester Anderson via Qgis-user wrote:
> Hello all,
> I had to apply a "fix geometries" on a shapefile which worked fine. However, it appears to move the fixed elements to the top of the table and as a result the sequence is out of order, e.g.:
> Is it possible to put things back in the correct order (by ID); 12 and 13 should be the last rows ?
> Thanks
> Lester
> Qgis-user mailing list
