[Qgis-user] Attribute table issue
Lester Anderson
arctica1963 at gmail.com
Fri May 13 00:06:46 PDT 2022
Problem sorted.
On Fri, 13 May 2022 at 07:21, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> Hi,
> The attribute table is a 'view' on your data. The (technical) order of
> your data is not important is it?
> Anyway: you can click on the ID column to make the attribute table sort on
> ID column (or click again to do a reverse sort)
> HTH
> Regards,
> On 5/13/22 07:59, Lester Anderson via Qgis-user wrote:
> > Hello all,
> > I had to apply a "fix geometries" on a shapefile which worked fine.
> However, it appears to move the fixed elements to the top of the table and
> as a result the sequence is out of order, e.g.:
> > Is it possible to put things back in the correct order (by ID); 12 and
> 13 should be the last rows ?
> > Thanks
> > Lester
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220513/0552846b/attachment.htm>
