[Qgis-user] No Quickmap Plugin For New Versions of QGis
Dan Grasso
dangrasso at live.com
Thu May 12 12:25:50 PDT 2022
Good Day,
> > I was hoping you could help describe how to download the Quickmap plugin for version 3.24. The plugin menu is a lot different than version 3.14. A lot more plug in categories are listed in 3.14.
> > Also the plugins used to show up in the Web column after they were downloaded. However every version after 3.14 deleted the web column.
> > When I try to search for plugins I have no luck finding Quickmaps.
> > Can you please tell me how to download Quickmaps in the new version 3.24?
> > Also can you please explain why the plugin menu is now a lot less helpful than version 3.14?
> > Can you also please explain why you deleted the web column which allowed me to view the plugins I downloaded?
> > If these items have been moved to another place, can you please explain so I can actually try to use the new version?
> > Thanks alot!
> > Have a great day!
> > Dan Grasso
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220512/c5866dd7/attachment.htm>
