[Qgis-user] No Quickmap Plugin For New Versions of QGis
Richard Duivenvoorde
rdmailings at duif.net
Thu May 12 23:50:27 PDT 2022
The menu will 'fill' itself according to needs.
So if you do not have any 'web' plugins, the 'web'-menu will not show.
Use the Plugin Manager to install QuickMap plugin (and google around for further instructions)
Regards,
On 5/12/22 21:25, Dan Grasso via Qgis-user wrote:
> Good Day,
>> > I was hoping you could help describe how to download the Quickmap plugin for version 3.24. The plugin menu is a lot different than version 3.14. A lot more plug in categories are listed in 3.14.
>> > Also the plugins used to show up in the Web column after they were downloaded. However every version after 3.14 deleted the web column.
>> > When I try to search for plugins I have no luck finding Quickmaps.
>> > Can you please tell me how to download Quickmaps in the new version 3.24?
>> > Also can you please explain why the plugin menu is now a lot less helpful than version 3.14?
>> > Can you also please explain why you deleted the web column which allowed me to view the plugins I downloaded?
>> > If these items have been moved to another place, can you please explain so I can actually try to use the new version?
>> > Thanks alot!
>> > Have a great day!
>> > Dan Grasso
> Qgis-user mailing list
