[Qgis-user] issue with ”Task complete: Counting features in...”
Alexandru Munteanu
aldru.munteanu at gmail.com
Mon May 16 02:43:50 PDT 2022
Thank you, Nicolas, for your reply!
Yes, the project is on drive, with offline access. We use it so we can
work remotely.
I have tried the following:
1. I copied the project on computer - it didn't work
2. deleted the wms layers - no luck
3. also tried to reduce the number of layers to have only the layers i
use for a print layout - it still freezes and sometimes (not always)
counts the features.
Also, another problem is when i save the project and close it - i have
to forcibly shut it as it also freezes and wont close on its own.
Maybe i am doing something wrong, i don't know.
Best,
Alexandru
On 14.05.2022 18:43, Nicolas Cadieux wrote:
> Hi,
> I suspect the wms server is possibly causing this slowdown. Have you
> tried the same project without the wms layers? Are the other layer
> stored locally or on a file server? That could also cause a slowing down.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>> Le 14 mai 2022 à 11:01, Alexandru Munteanu via Qgis-user
>> <qgis-user at lists.osgeo.org> a écrit :
>> Hello,
>> I am encountering an issue that dramatically slows down the work flow
>> in qgis. I am using the version 3.24.
>> My project consists of more then 100 layers, both shp and wms. These
>> projects are city master plans, an they are quite bulky, data wise.
>> The issue is that every time i make an operation, the program runs a
>> process ending with the message ”Task complete: Counting features in
>> ...(layer)”. This especially happens when i compile print layouts and
>> edit anything in the print layout. When this happens the program
>> freezes to points when i have to forcibly restart the program.
>> Did anyone encounter similar problems? Is there way around that? Can
>> i make it stop counting the features?
>> Or maybe do you have tips on how i can change the work flow?
>> The idea is that when i finish the project i should print around 15
>> thematic layouts.
>> Thank you for any info you could provide me on that!
>> Best,
>> Alexandru
>> Alexandru Munteanu
>> Centre of Urbanism, co-founder, president
>> MSc. in International Cooperation in Urban Development
>> MSc. in Urbanism, Habitat and International Cooperation
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandru Munteanu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220516/0611339b/attachment.htm>
