[Qgis-user] issue with ”Task complete: Counting features in...”
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Sat May 14 08:43:01 PDT 2022
I suspect the wms server is possibly causing this slowdown. Have you tried the same project without the wms layers? Are the other layer stored locally or on a file server? That could also cause a slowing down.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 14 mai 2022 à 11:01, Alexandru Munteanu via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Hello,
> I am encountering an issue that dramatically slows down the work flow in qgis. I am using the version 3.24.
> My project consists of more then 100 layers, both shp and wms. These projects are city master plans, an they are quite bulky, data wise.
> The issue is that every time i make an operation, the program runs a process ending with the message ”Task complete: Counting features in ...(layer)”. This especially happens when i compile print layouts and edit anything in the print layout. When this happens the program freezes to points when i have to forcibly restart the program.
> Did anyone encounter similar problems? Is there way around that? Can i make it stop counting the features?
> Or maybe do you have tips on how i can change the work flow?
> The idea is that when i finish the project i should print around 15 thematic layouts.
> Thank you for any info you could provide me on that!
> Best,
> Alexandru
> Alexandru Munteanu
> Centre of Urbanism, co-founder, president
> MSc. in International Cooperation in Urban Development
> MSc. in Urbanism, Habitat and International Cooperation
> aldru.munteanu at gmail.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220514/71bbd528/attachment.htm>
