[Qgis-user] issue with ”Task complete: Counting features in...”
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Mon May 16 12:39:53 PDT 2022
Follow the tips other have given you. Also, disable all plugins, try creating a new user profile.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 16 mai 2022 à 05:43, Alexandru Munteanu <aldru.munteanu at gmail.com> a écrit :
> Thank you, Nicolas, for your reply!
> Yes, the project is on drive, with offline access. We use it so we can work remotely.
> I have tried the following:
> 1. I copied the project on computer - it didn't work
> 2. deleted the wms layers - no luck
> 3. also tried to reduce the number of layers to have only the layers i use for a print layout - it still freezes and sometimes (not always) counts the features.
> Also, another problem is when i save the project and close it - i have to forcibly shut it as it also freezes and wont close on its own.
> Maybe i am doing something wrong, i don't know.
> Best,
> Alexandru
> On 14.05.2022 18:43, Nicolas Cadieux wrote:
>> Hi,
>> I suspect the wms server is possibly causing this slowdown. Have you tried the same project without the wms layers? Are the other layer stored locally or on a file server? That could also cause a slowing down.
>> Nicolas Cadieux
>>> Le 14 mai 2022 à 11:01, Alexandru Munteanu via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
>>> Hello,
>>> I am encountering an issue that dramatically slows down the work flow in qgis. I am using the version 3.24.
>>> My project consists of more then 100 layers, both shp and wms. These projects are city master plans, an they are quite bulky, data wise.
>>> The issue is that every time i make an operation, the program runs a process ending with the message ”Task complete: Counting features in ...(layer)”. This especially happens when i compile print layouts and edit anything in the print layout. When this happens the program freezes to points when i have to forcibly restart the program.
>>> Did anyone encounter similar problems? Is there way around that? Can i make it stop counting the features?
>>> Or maybe do you have tips on how i can change the work flow?
>>> The idea is that when i finish the project i should print around 15 thematic layouts.
>>> Thank you for any info you could provide me on that!
>>> Best,
>>> Alexandru
>>> Alexandru Munteanu
>>> Centre of Urbanism, co-founder, president
>>> MSc. in International Cooperation in Urban Development
>>> MSc. in Urbanism, Habitat and International Cooperation
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandru Munteanu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220516/54a87173/attachment.htm>
