[Qgis-user] issue with ”Task complete: Counting features in...”
Alexandru Munteanu
aldru.munteanu at gmail.com
Mon May 16 13:39:57 PDT 2022
Hi all,
Thank you for the tips! Unfortunately nothing worked.
In the main window, feature counting in layers is not activated, nor it is
active in the legend in the print layout.
A new user with no plugins installed also didn't give any improvements.
I'm thinking it might be something related with the print layout because it
mainly counts features when i edit the legend or change the scale of the
map.
Best,
A
On Mon, May 16, 2022, 22:39 Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Follow the tips other have given you. Also, disable all plugins, try
> creating a new user profile.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 16 mai 2022 à 05:43, Alexandru Munteanu <aldru.munteanu at gmail.com> a
> écrit :
> Thank you, Nicolas, for your reply!
> Yes, the project is on drive, with offline access. We use it so we can
> work remotely.
> I have tried the following:
> 1. I copied the project on computer - it didn't work
> 2. deleted the wms layers - no luck
> 3. also tried to reduce the number of layers to have only the layers i use
> for a print layout - it still freezes and sometimes (not always) counts the
> features.
> Also, another problem is when i save the project and close it - i have to
> forcibly shut it as it also freezes and wont close on its own.
> Maybe i am doing something wrong, i don't know.
> Best,
> Alexandru
> On 14.05.2022 18:43, Nicolas Cadieux wrote:
> Hi,
> I suspect the wms server is possibly causing this slowdown. Have you tried
> the same project without the wms layers? Are the other layer stored
> locally or on a file server? That could also cause a slowing down.
> Nicolas Cadieux
> Le 14 mai 2022 à 11:01, Alexandru Munteanu via Qgis-user
> <qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org> a écrit :
> Hello,
> I am encountering an issue that dramatically slows down the work flow in
> qgis. I am using the version 3.24.
> My project consists of more then 100 layers, both shp and wms. These
> projects are city master plans, an they are quite bulky, data wise.
> The issue is that every time i make an operation, the program runs a
> process ending with the message ”Task complete: Counting features in
> ...(layer)”. This especially happens when i compile print layouts and edit
> anything in the print layout. When this happens the program freezes to
> points when i have to forcibly restart the program.
> Did anyone encounter similar problems? Is there way around that? Can i
> make it stop counting the features?
> Or maybe do you have tips on how i can change the work flow?
> The idea is that when i finish the project i should print around 15
> thematic layouts.
> Thank you for any info you could provide me on that!
> Best,
> Alexandru
> Alexandru Munteanu
> Centre of Urbanism, co-founder, president
> MSc. in International Cooperation in Urban Development
> MSc. in Urbanism, Habitat and International Cooperationaldru.munteanu at gmail.com
> Qgis-user mailing list
> Alexandru Munteanu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220516/223b4ef6/attachment.htm>
