[Qgis-user] issue with ”Task complete: Counting features in...”
Alexandru Munteanu
aldru.munteanu at gmail.com
Tue May 17 02:26:45 PDT 2022
Thank you! will have a look into that, maybe this will be a better solution
A.
On 17.05.2022 02:47, Nicolas Cadieux wrote:
> Hi,
> I have been using the Atlas features lately. The legend is indeed
> very slow when you activate various functions like show only features
> on the map. This does require the legend to look at the fields
> defending on the layer styles and then check what is on the map. This
> is very slow.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>> Le 16 mai 2022 à 16:40, Alexandru Munteanu <aldru.munteanu at gmail.com>
>> a écrit :
>> Hi all,
>> Thank you for the tips! Unfortunately nothing worked.
>> In the main window, feature counting in layers is not activated, nor
>> it is active in the legend in the print layout.
>> A new user with no plugins installed also didn't give any improvements.
>> I'm thinking it might be something related with the print layout
>> because it mainly counts features when i edit the legend or change
>> the scale of the map.
>> Best,
>> A
>> On Mon, May 16, 2022, 22:39 Nicolas Cadieux
>> <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> Follow the tips other have given you. Also, disable all plugins,
>> try creating a new user profile.
>> Nicolas Cadieux
>>> Le 16 mai 2022 à 05:43, Alexandru Munteanu
>>> <aldru.munteanu at gmail.com> a écrit :
>>> Thank you, Nicolas, for your reply!
>>> Yes, the project is on drive, with offline access. We use it so
>>> we can work remotely.
>>> I have tried the following:
>>> 1. I copied the project on computer - it didn't work
>>> 2. deleted the wms layers - no luck
>>> 3. also tried to reduce the number of layers to have only the
>>> layers i use for a print layout - it still freezes and sometimes
>>> (not always) counts the features.
>>> Also, another problem is when i save the project and close it -
>>> i have to forcibly shut it as it also freezes and wont close on
>>> its own.
>>> Maybe i am doing something wrong, i don't know.
>>> Best,
>>> Alexandru
>>> On 14.05.2022 18:43, Nicolas Cadieux wrote:
>>>> Hi,
>>>> I suspect the wms server is possibly causing this slowdown.
>>>> Have you tried the same project without the wms layers? Are
>>>> the other layer stored locally or on a file server? That could
>>>> also cause a slowing down.
>>>> Nicolas Cadieux
>>>>> Le 14 mai 2022 à 11:01, Alexandru Munteanu via Qgis-user
>>>>> <qgis-user at lists.osgeo.org> <mailto:qgis-user at lists.osgeo.org>
>>>>> a écrit :
>>>>> Hello,
>>>>> I am encountering an issue that dramatically slows down the
>>>>> work flow in qgis. I am using the version 3.24.
>>>>> My project consists of more then 100 layers, both shp and wms.
>>>>> These projects are city master plans, an they are quite bulky,
>>>>> data wise.
>>>>> The issue is that every time i make an operation, the program
>>>>> runs a process ending with the message ”Task complete:
>>>>> Counting features in ...(layer)”. This especially happens when
>>>>> i compile print layouts and edit anything in the print layout.
>>>>> When this happens the program freezes to points when i have to
>>>>> forcibly restart the program.
>>>>> Did anyone encounter similar problems? Is there way around
>>>>> that? Can i make it stop counting the features?
>>>>> Or maybe do you have tips on how i can change the work flow?
>>>>> The idea is that when i finish the project i should print
>>>>> around 15 thematic layouts.
>>>>> Thank you for any info you could provide me on that!
>>>>> Best,
>>>>> Alexandru
>>>>> Alexandru Munteanu
>>>>> Centre of Urbanism, co-founder, president
>>>>> MSc. in International Cooperation in Urban Development
>>>>> MSc. in Urbanism, Habitat and International Cooperation
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Alexandru Munteanu
Alexandru Munteanu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220517/f0a65a85/attachment-0001.htm>
