[Qgis-user] Problem merging 30-m SRTM tiles in QGIS 3.24.3 for MacOS 10.14.6
    Richard McDonnell
    richard.mcdonnell at opw.ie
    Fri May 20 03:34:42 PDT 2022
Hi Walter,
As an alternative to Wouter’s suggestion, I would recommend VRT’s (Raster ==> Miscellaneous ==> Build Virtual Raster) Not alone does it merge/mosaic but it also results in a small file size. It is also very easy to generate convert that VRT to any other format output, using gdal_translate (Raster ==> Conversion ==> Translate)
I hope this helps,
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://www.opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Wouter Impens via Qgis-user
Sent: 20 May 2022 11:04
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Problem merging 30-m SRTM tiles in QGIS 3.24.3 for MacOS 10.14.6
Hi Walter,
I'm having good results using the 'r.patch' tool from GRASS for merging rasters.
Hope this helps
Greetings
Wouter
Op do 19 mei 2022 om 23:31 schreef Walter Alvarez via Qgis-user <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>:
I’m trying to merge either two or twelve 30-m SRTM tiles using QGIS 3.14.3.  In either case (2 or 12) I am stopped by the following problem:
Using Raster > Miscellaneous > Merge…
I get the “Merge" window.   I try to use Input layers > Elements selected > “…"
That takes me to the "Multiple Selection" window, showing the 2 or 12 files I want to merge (filenames:   nXXeXXX_1arc_v3 [EPSG:4326]).
After selecting all the files, when I click “OK”   the "Multiple Selection Window” and the “Merge” window both disappear, and I cannot figure out what to do next, or do differently.
I can’t figure out how to get past this problem and merge my tiles.
Thanks for any help you can offer!
Walter
__________
Walter Alvarez
Professor of the Graduate School
Department of Earth and Planetary Science
University of California Berkeley
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220520/6b5e47c8/attachment-0001.htm>
