[Qgis-user] Problem merging 30-m SRTM tiles in QGIS 3.24.3 for MacOS 10.14.6
Wouter Impens
wouter.impens at gmail.com
Fri May 20 03:03:48 PDT 2022
Hi Walter,
I'm having good results using the 'r.patch' tool from GRASS for merging
rasters.
Hope this helps
Greetings
Wouter
Op do 19 mei 2022 om 23:31 schreef Walter Alvarez via Qgis-user <
qgis-user at lists.osgeo.org>:
> I’m trying to merge either two or twelve 30-m SRTM tiles using QGIS
> 3.14.3. In either case (2 or 12) I am stopped by the following problem:
> Using Raster > Miscellaneous > Merge…
> I get the “Merge" window. I try to use Input layers > Elements selected
> That takes me to the "Multiple Selection" window, showing the 2 or 12
> files I want to merge (filenames: nXXeXXX_1arc_v3 [EPSG:4326]).
> After selecting all the files, when I click “OK” the "Multiple Selection
> Window” and the “Merge” window both disappear, and I cannot figure out what
> to do next, or do differently.
> I can’t figure out how to get past this problem and merge my tiles.
> Thanks for any help you can offer!
> Walter
> __________
> Walter Alvarez
> Professor of the Graduate School
> Department of Earth and Planetary Science
> University of California Berkeley
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220520/ce3bce4c/attachment.htm>
