[Qgis-user] No GetFeatureInfo request sent in QGIS Desktop on WMS layer
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri May 20 09:19:46 PDT 2022
Hi Andreas,
(so great to see the QGIS + MapServer communities working together here)
Inspired by your questions today, I gave another round of updates to the
MapServer documentation, improving the examples for GetFeatureInfo etc.
Besides what was mentioned already, you might also consider setting the
"gml_" metadata parameters for your layer, to send the geometry as part
of the "Feature" response (in the Identify Results / GetFeatureInfo
window of QGIS, select "Feature" in the dropdown box) [note that often
that Feature dropdown is blank in that QGIS window until I first chose
either "text" or "html" and reselect "Feature" to get the GML format
request through GetFeatureInfo sent back to QGIS]. Here are those
parameters:
MAP
WEB
METADATA
"wms_title" "WMS Demo Server" ##required
"wms_abstract" "Longer description of your service"
##recommended
"wms_onlineresource"
"http://yourpath/cgi-bin/mapserv.exe?map=/path/to/your-mapfile.map"
##required (must change mapfile path)
"wms_srs" "EPSG:3978 EPSG:3857 EPSG:4269 EPSG:4326"
##recommended
"wms_enable_request" "*" ##required
"wms_getfeatureinfo_formatlist"
"text/plain,text/html,application/vnd.ogc.gml,gml" ##recommended
END #metadata
END #web
LAYER
METADATA
"wms_title" "Parks" ##required
"wms_abstract" "Longer description of your layer" ##recommended
"wms_include_items" "all" ##optional
"gml_include_items" "all" ##optional
"gml_featureid" "ogc_fid" ##optional
"gml_geometries" "msgeom" ##optional
"gml_msgeom_type" "multipolygon" ##optional
END #metadata
TEMPLATE "empty" ##recommended (enable GetFeatureInfo / can point
to valid .html template)
END #layer
END #map
Or see the example WMS Server mapfile at:
https://mapserver.org/ogc/wms_server.html#sample-wms-server-mapfile
Again, it's excellent to see the QGIS & MapServer communities working
together, thanks for this! :)
PS. I bet I've listed QGIS there on that WMS Server document page for
now 20 years, as the recommended desktop client for testing, ha.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-05-20 4:41 a.m., Andreas Neumann via Qgis-user wrote:
> Hi Barend,
> Thanks. It's been a while since I last worked with UMN map server.
> I must have been "blind" not to see the queryable="0" in the
> Capabilities response.
> Your suggestions helped. All fine now!
> Thanks a lot,
> ANdreas
> On 2022-05-20 09:18, Kobben, Barend (UT-ITC) wrote:
>> Your mMAP set up apparently is wrong, because contrary to what you
>> think, the layer is NOT queryable:
>> <Layer queryable="0" opaque="0" cascaded="0">
>> <Name>cave_entrances</Name>
>> Usualy this means you have to set appropriate things in the .map file,
>> such as
>> First, we have to prepare MapServer to actually be set up to respond
>> to the request in a way the OpenLayers script can handle:
>> Edit your .map file. In *each* LAYER object you want to query, put the
>> lines:
>> TOLERANCE 5
>> TOLERANCEUNITS pixels
>> In each LAYER object's METADATA put the extra line:
>> In each CLASS object put the extra line:
>> TEMPLATE "empty"
>> /Barend Köbben/
>> On 20/05/2022, 09:10, "Qgis-user on behalf of Andreas Neumann via
>> Qgis-user" <qgis-user-bounces at lists.osgeo.org
>> <mailto:qgis-user-bounces at lists.osgeo.org> on behalf of
>> qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> wrote:
>> Hi,
>> I am experimenting with a very simple/basic WMS served by UMN Mapserver.
>> For some reasons, GetFeatureInfo does not work, although it is
>> "advertised" as available in the GetCapabilities reponse.
>> Here is the test service:
>> http://159.100.248.156/cgi-bin/mapserv.fcgi?map=/home/ubuntu/umn_mapfiles/cave_entrances.map
>> <http://159.100.248.156/cgi-bin/mapserv.fcgi?map=/home/ubuntu/umn_mapfiles/cave_entrances.map>
>> and a link to the GetCapabilities request
>> http://159.100.248.156/cgi-bin/mapserv.fcgi?map=/home/ubuntu/umn_mapfiles/cave_entrances.map&SERVICE=WMS&REQUEST=GetCapabilities
>> <http://159.100.248.156/cgi-bin/mapserv.fcgi?map=/home/ubuntu/umn_mapfiles/cave_entrances.map&SERVICE=WMS&REQUEST=GetCapabilities>
>> When I load this layer, i get the two points in the data set, but I
>> can't query them. QGIS says "No feature found at this position" and in
>> the network debugging session I see that no request is sent to the server.
>> Do you have any idea what might be wrong with this WMS service?
>> Thank you and greetings,
>> Andreas
