[Qgis-user] No GetFeatureInfo request sent in QGIS Desktop on WMS layer
Andreas Neumann
a.neumann at carto.net
Fri May 20 00:41:28 PDT 2022
Hi Barend,
Thanks. It's been a while since I last worked with UMN map server.
I must have been "blind" not to see the queryable="0" in the
Capabilities response.
Your suggestions helped. All fine now!
Thanks a lot,
ANdreas
On 2022-05-20 09:18, Kobben, Barend (UT-ITC) wrote:
> Your mMAP set up apparently is wrong, because contrary to what you
> think, the layer is NOT queryable:
> <Layer queryable="0" opaque="0" cascaded="0">
> <Name>cave_entrances</Name>
> Usualy this means you have to set appropriate things in the .map file,
> such as
> First, we have to prepare MapServer to actually be set up to respond to
> the request in a way the OpenLayers script can handle:
> Edit your .map file. In each LAYER object you want to query, put the
> lines:
> TOLERANCE 5
> TOLERANCEUNITS pixels
> In each LAYER object's METADATA put the extra line:
> "wms_include_items" "all"
> In each CLASS object put the extra line:
> TEMPLATE "empty"
> _-- _
> _Barend Köbben_
> On 20/05/2022, 09:10, "Qgis-user on behalf of Andreas Neumann via
> Qgis-user" <qgis-user-bounces at lists.osgeo.org on behalf of
> qgis-user at lists.osgeo.org> wrote:
> Hi,
> I am experimenting with a very simple/basic WMS served by UMN
> Mapserver.
> For some reasons, GetFeatureInfo does not work, although it is
> "advertised" as available in the GetCapabilities reponse.
> Here is the test service:
> http://159.100.248.156/cgi-bin/mapserv.fcgi?map=/home/ubuntu/umn_mapfiles/cave_entrances.map
> [1]
> and a link to the GetCapabilities request
> http://159.100.248.156/cgi-bin/mapserv.fcgi?map=/home/ubuntu/umn_mapfiles/cave_entrances.map&SERVICE=WMS&REQUEST=GetCapabilities
> When I load this layer, i get the two points in the data set, but I
> can't query them. QGIS says "No feature found at this position" and in
> the network debugging session I see that no request is sent to the
> server.
> Do you have any idea what might be wrong with this WMS service?
> Thank you and greetings,
> Andreas
Links:
[1]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220520/304f7c7a/attachment.htm>
