[Qgis-user] Problem merging 30-m SRTM tiles in QGIS 3.24.3 for MacOS 10.14.6
Fielding, Eric J (US 329A) eric.j.fielding at jpl.nasa.gov
Fri May 20 11:54:27 PDT 2022
Hi Walter,
I think the problem was that your iCloud folder or some other directory on the path to the files had a space in the name. Many of the QGIS functions don't work correctly if there is a space in any name any part of the file path.
++Eric
Eric Fielding
Eric.J.Fielding at jpl.nasa.gov
http://science.jpl.nasa.gov/people/Fielding/
Twitter: @EricFielding
> From: Walter Alvarez
> Thank you, Thayer!  That indeed was part of the problem, but I believe another problem was that the files were
> saved in iCloud.  When I took them
> out of iCloud and looked for the hidden Tools window, the DEMs merged >properly!  I greatly appreciate your help!
> Walter
> On May 20, 2022, at 6:01 AM, Thayer Young <https://lists.osgeo.org/mailman/listinfo/qgis-user> wrote:
> Hi Walter,
> Sometimes after entering parameters the tool window drops behind the main QGIS window. Try either moving the QGIS window out of the way or right click the QGIS icon in the Dock and select "Show All Windows" and see if you can find it again. Hope this helps.
> -Thayer
> On Friday, May 20, 2022, 06:35:24 AM EDT, https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user> wrote:
> Date: Thu, 19 May 2022 14:30:39 -0700
> I?m trying to merge either two or twelve 30-m SRTM tiles using QGIS 3.14.3.  In either case (2 or 12) I am stopped by the following problem:
> Using Raster > Miscellaneous > Merge?
> I get the ?Merge" window.  I try to use Input layers > Elements selected > ??"
> That takes me to the "Multiple Selection" window, showing the 2 or 12 files I want to merge (filenames:  nXXeXXX_1arc_v3 [EPSG:4326]).
> After selecting all the files, when I click ?OK?  the "Multiple Selection Window? and the ?Merge? window both disappear, and I cannot figure out what to do next, or do differently.
> I can?t figure out how to get past this problem and merge my tiles.
> Thanks for any help you can offer!
