[Qgis-user] Identify tool and closest vertices (z-values)
Andreas Neumann
a.neumann at carto.net
Tue May 24 01:52:32 PDT 2022
We have a a Postgis PolygonZ data set an want to query the third
dimension of the closest vertex. According to my users, this used to
work fine in older QGIS versions, but now we can only see the x/y values
and not z-values anymore.
I just tested it on QGIS 3.22 (LTR) and can conform that the z-values
are not displayed in the derived data of the identify tool.
Is there any hidden setting that helps us to display the z-values again
- or a connection parameter that forces QGIS to treat it correctly as a
3d data set?
Thank you for any hints,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220524/a57279a0/attachment.htm>
