[Qgis-user] Raster
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed May 25 07:14:23 PDT 2022
Another way is to add an alpha band to the image. I generally use GIMP
to do this. If the Georeferencer sees and alpha band, then, the border
will use this band.
Nicolas
On 2022-05-24 7:25 a.m., Richard McDonnell via Qgis-user wrote:
> Easiest way I can think of doing what you want is to create a VRT of
> the three raster’s.
> *Raster*è*Miscellaneous* è*Build Virtual Raster*
> When you do this set the *Nodata value* to 0 (the default transparent
> value form the Georeference Tool)
> This should create a merged raster for you and allow you to use the
> correct transparency value.
> Hope this helps,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> /FRM Data Management/
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> https://www.opw.ie
> Email Disclaimer: https://www.opw.ie/en/disclaimer/
> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of
> *Lazanu Ciprian-Catalin via Qgis-user
> *Sent:* 24 May 2022 11:53
> *To:* Uwe Fischer via Qgis-user <qgis-user at lists.osgeo.org>; Uwe
> *Subject:* [Qgis-user] Raster
> Hello,
> I georeferenced three maps ... all good, quite easy by using points
> from map canvas. When my map was ready it has a black border (image
> 1). This is solved by ~Custom transparency options~, and a black
> border disappears. But this solution is just temporarily, because if I
> close and reopen ... that raster has again a black border. I want to
> merge the three maps in one, but it does with a black border between
> maps.
> A solution to this annoying problem?
> Thank you
> https://drive.google.com/drive/folders/1qM1_TeFUng9-xyRXRQCuMrEMwxFeJV7n?usp=sharing
> <https://drive.google.com/drive/folders/1qM1_TeFUng9-xyRXRQCuMrEMwxFeJV7n?usp=sharing> images
> Meet Google Drive – One place for all your files
> Google Drive is a free way to keep your files backed up and easy to
> reach from any phone, tablet, or computer. Start with 15GB of Google
> storage – free.
> drive.google.com
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220525/760c5404/attachment-0001.htm>
