[Qgis-user] Error export .shp to .gpx
    Mike Breiding - Morgantown WV
    epicroadtrips at gmail.com
    Sat May 28 05:14:13 PDT 2022
Greetings,
I get the following error when I try to export .shp to .gpx.
I do not understand what is meant by "Use GPX_USE_EXTENSIONS creation
option..."
Can any help with this?
Thanks,
WV-Mike
"Export to vector file failed.
Error: Creation of field VERSION failed (OGR error: Field of name
'VERSION' is not supported in GPX schema. Use GPX_USE_EXTENSIONS
creation option to allow use of the <extensions> element.)"
Mike Breiding
www.EpicRoadTrips.us
