[Qgis-user] Error export .shp to .gpx
Fernando M. Roxo da Motta
petro at roxo.org
Sat May 28 05:56:09 PDT 2022
On Sat, 28 May 2022 08:14:13 -0400, Mike Breiding - Morgantown WV via
Qgis-user <qgis-user at lists.osgeo.org> wrote:
> Greetings,
> I get the following error when I try to export .shp to .gpx.
> I do not understand what is meant by "Use GPX_USE_EXTENSIONS creation
> option..."
See:
https://gis.stackexchange.com/questions/40731/converting-shp-into-gpx-using-qgis
> Can any help with this?
> Thanks,
> WV-Mike
> "Export to vector file failed.
> Error: Creation of field VERSION failed (OGR error: Field of name
> 'VERSION' is not supported in GPX schema. Use GPX_USE_EXTENSIONS
> creation option to allow use of the <extensions> element.)"
Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
Except where explicitly stated I speak on my own behalf.| VI !!
PU5RXO | PX5Q6048 | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
