[Qgis-user] Error export .shp to .gpx
Mike Breiding - Morgantown WV epicroadtrips at gmail.com
Sat May 28 09:22:25 PDT 2022
On 5/28/2022 8:56 AM, Fernando M. Roxo da Motta wrote:
> On Sat, 28 May 2022 08:14:13 -0400, Mike Breiding - Morgantown WV via
> Qgis-user <qgis-user at lists.osgeo.org> wrote:
>> Greetings,
>> I get the following error when I try to export .shp to .gpx.
>> I do not understand what is meant by "Use GPX_USE_EXTENSIONS creation
>> option..."
>See: https://gis.stackexchange.com/questions/40731/converting-shp-into-gpx-using-qgis
Thanks, Fernando.
Did you have a particular solution in mind? There are several listed. I
am a newbie and all of the solutions mentioned are over my head.
I should have mentioned I am using 3.16.16-Hannover on WIN 7
Thanks,
WV-Mike
>> Can any help with this?
>> Thanks,
>> WV-Mike
>> "Export to vector file failed.
>> Error: Creation of field VERSION failed (OGR error: Field of name
>> 'VERSION' is not supported in GPX schema. Use GPX_USE_EXTENSIONS
>> creation option to allow use of the <extensions> element.)"
>    Roxo
