[Qgis-user] adding a layer from a zipped file
Phil Wyatt
phil at wyatt-family.com
Sat May 28 21:03:22 PDT 2022
Hi Stephen,
You might let us know your operating system and which version of QGIS you are using because it works as you desire in the latest development (3.24.3) and Long Term Release versions (3.22.7). It may just be a matter of updating QGIS.
Cheers - Phil
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Stephen Sacks via Qgis-user
Sent: Sunday, 29 May 2022 5:29 AM
To: qgis forum <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] adding a layer from a zipped file
When I write a layer as a shape file, it appears on my C: drive as six files, all with the same name but different extensions. Then I zip those six into a single file (xxx.zip). When I reload that layer from the zip file (Layer > AddLayer > VectorLayer > File > Dataset > xxx.zip), QGIS is almost smart enough to restore the layer correctly. The polygon features are in the right place and their attribute table is correct. My problem is that it ignores one of the six files, the "style" file (xxx .qml) which specifies color, labeling, and symbol). Do I have to unzip before restoring layer xxx ? I know I could open the layer's properties and use Style > Load Style from file xxx.qml . But when I'm restoring several layers that's a lot of key strokes (and may require that I unzip). It seems to me that this shouldn't be necessary. [I encounter the same problem with point layers and polygon layers.]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220529/b034d324/attachment.htm>
