[Qgis-user] How-to-Batch_convert the Spatial resolution of a set of >100 Geotiff files from 500m to 1000m
Randal Hale
rjhale at northrivergeographic.com
Tue May 31 12:48:57 PDT 2022
I'm pretty sure 3.18 had Batch processing - but I do concur with Nicolas
- check and make sure that works on windows 7.
Right click on that processing tool and see if you have a batch option.
On 5/31/22 15:42, Nicolas Cadieux wrote:
> Hi,
> I think you need a 64bit version of Windows…. Make sure it’s
> compatible with Windows 7. You may need Windows 10 because of the
> latest versions of Python…
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>> Le 31 mai 2022 à 15:38, Amal Kar via Qgis-user
>> <qgis-user at lists.osgeo.org> a écrit :
>> THANK YOU VERY MUCH, SIR!
>> I shall first replace my present QGIS software (ver. 3.18.2, Zurich)
>> with the new one (ver. 3.24), and then use the procedure for batch
>> processing.
>> Hope the new version runs on my old Windows 7.
>> Thanks again for the tips.
>> Regards,
>> amal kar.
>> On Tue, 31 May 2022 at 21:28, Randal Hale
>> <rjhale at northrivergeographic.com> wrote:
>> Depending on which version of QGIS you have (3.22, 3.24 - you
>> can select the "translate" command in the processing toolbox
>> (you'll find that under gdal -> raster conversion) and either
>> right click the tool and run as batch process or in 3.24 you can
>> select the batch button from the translate menu.
>> You can grab all the imagery from a directory and convert it. I
>> will admit that batch processing does throw me off just a bit -
>> BUT - work with it and it should do what you want.
>> Randy
>> On 5/31/22 11:28, Amal Kar via Qgis-user wrote:
>>> Hello,
>>> I am new to QGIS.
>>> Recently i downloaded a set of MODIS Terra surface reflectance
>>> Daily data for a fixed rectangular area of my interest (118
>>> daily files for each of the bands 1-4 and for years 2000-2020),
>>> using the AppEEARS tool (NASA-USGS-LP DAAC) in geotiff format
>>> (WGS 84; LatLong).
>>> I wanted to convert the original data in 500 m spatial resolution
>>> (0.0041667 arc deg; 2985 col x 1671 row for each scene) to 1 km
>>> resolution (0.00833333 arc deg; 1493 col x 836 row), so that i
>>> am able to create Max.value (& Min. value) Composites (MVCs) for
>>> consecutive 8-Day periods at 1 km resolution and then analyse
>>> the data sets for matching with other 8-Day data series
>>> available at 1 km resolution from Modis Terra sites.
>>> No downloaded data from AppEEARS is automatically 'imported" to
>>> my Idrisi software (neither geotiff, nor netCDF; same is the
>>> case with my GlobalMapper 8.0 software also; the same formats
>>> from other sites get converted easily). The file format could be
>>> read in my QGIS Desktop software (ver. 3.18.2; Zurich), and then
>>> exported either in geotiff or other formats (incl. idrisi) in
>>> whatever resolution, etc., i chose.
>>> Although i am doing it file by file, this is a huge
>>> back-breaking pre-processing task.
>>> I was thinking if there is any tool in QGIS for automatic batch
>>> processing of the data (say, 50 or 100 at one time, once i
>>> select the "Raster datasets" and "add" them in the given Box
>>> under "Data Source Manager"). Presently, after adding the
>>> datafiles, i have to select one raster image at a time and
>>> "Export" it with the desired resolution/ file format, etc. It
>>> helps if i am able to select all the files together, give one
>>> output resolution value and one desired file format for all the
>>> files to be processed). It also helps if the output data file
>>> uses the same name as given for the input file, but allows the
>>> user to provide a short prefix to each of them (say 4-6 letters,
>>> either replacing the first 4-6 ones, or adding to the given names).
>>> Once i am able to pre-process the data quickly, i am thinking of
>>> trying my QGIS for cloud removal (by providing a zero, No Data
>>> value to the cloud pixels) and then try it for getting MVCs for
>>> consecutive 8-day periods.
>>> Thanks for your patience, and kind regards,
>>> amal kar.
>>> Dr. Amal Kar
>>> Former Principal Scientist and Head, Division of Natural
>>> Resources & Environment,
>>> Central Arid Zone Research Institute, Jodhpur 342003, India
>>> A-1/6, Baitalik Housing Society, KMDA Housing Complex,
>>> Baghajatin (Near Hiland Park),
>>> KOLKATA 700 094, India
>>> Email: akarcaz50 at gmail.com
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Randal Hale
>> https://www.northrivergeographic.com
>> Dr. Amal Kar
>> Former Principal Scientist and Head, Division of Natural Resources &
>> Environment,
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220531/65ef8fa5/attachment-0001.htm>
