[Qgis-user] Problem insatalling from source
Werner Macho
werner.macho at gmail.com
Wed Nov 29 03:10:40 PST 2023
Hi!
According to the error message you provided you are missing:
Could not find a package configuration file provided by "Qt5SerialPort"
with any of the following names:
Try to install the package "libqt5serialport5-dev" (depending on which
distribution you are - I can only see it is a linux system)
regards
Werner
On Wed, Nov 29, 2023 at 12:05 PM Raivo Rebane via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> I want to install QGIS package from source, but got foolowing errors :
> CMake Error at cmake/FindSpatiaLite.cmake:20 (add_library):
> add_library cannot create ALIAS target "spatialite::spatialite" because
> target "PkgConfig::PC_SPATIALITE" is imported but not globally visible.
> Call Stack (most recent call first):
> CMakeLists.txt:405 (find_package)
> -- Qt WebKit support enabled
> -- Using embedded laz-perf
> -- Found ZSTD: /usr/lib/x86_64-linux-gnu/libzstd.so
> -- Found PDAL: pdal_base;pdal_util (2.2.0)
> -- Found Draco: /usr/local/lib/libdraco.a (1.5.6)
> CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
> (find_package):
> Qt5SerialPortConfig.cmake
> qt5serialport-config.cmake
> Add the installation prefix of "Qt5SerialPort" to CMAKE_PREFIX_PATH
> or set
> "Qt5SerialPort_DIR" to a directory containing one of the above files.
> If
> "Qt5SerialPort" provides a separate development package or SDK, be
> sure it
> has been installed.
> I tried different way of cmake :
> raivo at Hydra:~/QGIS/build-master$ cmake
> -DSPATIALITE_LIBRARY=/usr/lib/x86_64-linux-gnu/libspatialite.so
> -DSPATIALITE_INCLUDE_DIR=/usr/include/ ..
> and
> -DPC_SPATIALITE=/usr/lib/x86_64-linux-gnu/pkgconfig/spatialite.pc ..
> but in any cases got previous errors.
> What is wrong ?
> Regards,
> Raivo
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231129/f9cf579b/attachment.htm>
More information about the QGIS-User
