[Qgis-user] Problem insatalling from source
Werner Macho werner.macho at gmail.com
Wed Nov 29 03:14:19 PST 2023
And regarding spatialite ..
take a look if the -dev package of spatialite is installed ..
If you want to compile yourself you always need the -dev packages
regards
Werner
On Wed, Nov 29, 2023 at 12:10 PM Werner Macho <werner.macho at gmail.com>
wrote:
> Hi!
> According to the error message you provided you are missing:
> Could not find a package configuration file provided by "Qt5SerialPort"
>    with any of the following names:
> Try to install the package "libqt5serialport5-dev" (depending on which
> distribution you are - I can only see it is a linux system)
> regards
> Werner
> On Wed, Nov 29, 2023 at 12:05 PM Raivo Rebane via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hi,
>> I want to install QGIS package from source, but got foolowing errors :
>> CMake Error at cmake/FindSpatiaLite.cmake:20 (add_library):
>>    add_library cannot create ALIAS target "spatialite::spatialite" because
>>    target "PkgConfig::PC_SPATIALITE" is imported but not globally visible.
>> Call Stack (most recent call first):
>>    CMakeLists.txt:405 (find_package)
>> -- Qt WebKit support enabled
>> -- Using embedded laz-perf
>> -- Found ZSTD: /usr/lib/x86_64-linux-gnu/libzstd.so
>> -- Found PDAL: pdal_base;pdal_util (2.2.0)
>> -- Found Draco: /usr/local/lib/libdraco.a (1.5.6)
>> CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
>> (find_package):
>>      Qt5SerialPortConfig.cmake
>>      qt5serialport-config.cmake
>>    Add the installation prefix of "Qt5SerialPort" to CMAKE_PREFIX_PATH
>> or set
>>    "Qt5SerialPort_DIR" to a directory containing one of the above files.
>> If
>>    "Qt5SerialPort" provides a separate development package or SDK, be
>> sure it
>>    has been installed.
>> I tried different way of cmake :
>> raivo at Hydra:~/QGIS/build-master$ cmake
>> -DSPATIALITE_LIBRARY=/usr/lib/x86_64-linux-gnu/libspatialite.so
>> -DSPATIALITE_INCLUDE_DIR=/usr/include/ ..
>> and
>> -DPC_SPATIALITE=/usr/lib/x86_64-linux-gnu/pkgconfig/spatialite.pc ..
>> but in any cases got previous errors.
>> What is wrong ?
>> Regards,
>> Raivo
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231129/6b20f121/attachment.htm>
More information about the QGIS-User mailing list
