[Qgis-user] Problem insatalling from source
Raivo Rebane
raivo at r-systems.ee
Wed Nov 29 03:24:08 PST 2023
I have installed following :
2064 sudo apt-get install libspatialite-dev
2087 sudo apt install libqt5serialport5-dev
but same error ocured
Regards,
Raivo
On 29.11.23 13:14, Werner Macho wrote:
> And regarding spatialite ..
> take a look if the -dev package of spatialite is installed ..
> If you want to compile yourself you always need the -dev packages
> regards
> Werner
> On Wed, Nov 29, 2023 at 12:10 PM Werner Macho <werner.macho at gmail.com>
> wrote:
> Hi!
> According to the error message you provided you are missing:
> Could not find a package configuration file provided by
> "Qt5SerialPort"
> with any of the following names:
> Try to install the package "libqt5serialport5-dev" (depending on
> which distribution you are - I can only see it is a linux system)
> regards
> Werner
> On Wed, Nov 29, 2023 at 12:05 PM Raivo Rebane via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
> Hi,
> I want to install QGIS package from source, but got foolowing
> errors :
> CMake Error at cmake/FindSpatiaLite.cmake:20 (add_library):
> add_library cannot create ALIAS target
> "spatialite::spatialite" because
> target "PkgConfig::PC_SPATIALITE" is imported but not
> globally visible.
> Call Stack (most recent call first):
> CMakeLists.txt:405 (find_package)
> -- Qt WebKit support enabled
> -- Using embedded laz-perf
> -- Found ZSTD: /usr/lib/x86_64-linux-gnu/libzstd.so
> -- Found PDAL: pdal_base;pdal_util (2.2.0)
> -- Found Draco: /usr/local/lib/libdraco.a (1.5.6)
> CMake Error at
> /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
> (find_package):
> "Qt5SerialPort"
> Qt5SerialPortConfig.cmake
> qt5serialport-config.cmake
> Add the installation prefix of "Qt5SerialPort" to
> CMAKE_PREFIX_PATH
> or set
> "Qt5SerialPort_DIR" to a directory containing one of the
> above files. If
> "Qt5SerialPort" provides a separate development package or
> SDK, be
> sure it
> has been installed.
> I tried different way of cmake :
> raivo at Hydra:~/QGIS/build-master$ cmake
> -DSPATIALITE_LIBRARY=/usr/lib/x86_64-linux-gnu/libspatialite.so
> -DSPATIALITE_INCLUDE_DIR=/usr/include/ ..
> and
> -DPC_SPATIALITE=/usr/lib/x86_64-linux-gnu/pkgconfig/spatialite.pc
> but in any cases got previous errors.
> What is wrong ?
> Regards,
> Raivo
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231129/b909d031/attachment.htm>
More information about the QGIS-User
