[Qgis-user] Error Qgis Plugin 'PanoramaView'
Prova Itinerari
provaitinerari at gmail.com
Wed Apr 3 03:00:32 PDT 2024
Hi Emma,
already I had tried to uninstall it and install it again but I would get an
error saying that the path was not correct. But, I tried again a few
moments ago and was able to distill and then install again.
I try to do the same thing but I get the "wrong url" screen (see img
"output_panoramaview"), in that case what does it mean?
To create the user I went here (see img "profiles_qgis") but I get the same
image as before (see img "output_panoramaview") but at least for the moment
I don't get the black screen where it talked about WebGL (see img
"error_webGL")..
Please tell me if the steps are correct, anyway now I do more tests and if
I can't I contact the plugin creator directly.
In the meantime I thank you enormously.
Regards
Roberto
Il giorno mer 3 apr 2024 alle ore 03:48 Emma Hain <emma at north-road.com> ha
scritto:
> Hi Roberto
> I haven't used this but I checked out the instructions here
> <https://github.com/Kylsha/panorama_viewer>. When you uninstall it and
> install it, does the same thing happen? If so,create a new profile via
> Settings and install the plugin again and see what happens. If it works ok
> then its something in your profile that may be messing it up.
> If the same thing happens, I would add an issue here
> <https://github.com/Kylsha/panorama_viewer/issues>
> Good luck
> Em
> On Tue, 2 Apr 2024 at 23:04, Prova Itinerari via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hello everyone,
>> I have been using qgis recently. I installed the "PanoramaView" plugin
>> initially I was seeing the images, then I must have done something and now
>> I can't see them anymore. I get the visible error message as in the image.
>> But I to see them not used any browser, directly on Qgis I could see them
>> quietly. And so I wouldn't know what it was referring to. I saw if there
>> were problems with authentication and/or permissions and/or the path where
>> it gets the photos from aws DB but it is ok. I have formatted the various
>> browsers on the pc and it hasn't changed. Does anyone know how to fix it?
>> Has anyone experienced something like this before?
>> Thanks in advance to those who will answer me
>> Roberto
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Emma Hain — Product Manager/Senior GIS Analyst
> [image: https://north-road.com]
> *North Road*
> Cartography • Development • Spatial Analysis
> *north-road.com* <http://north-road.com>
> <https://twitter.com/northroadgeo>
> <https://www.linkedin.com/company/north-road-studios>
> <https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240403/1a2f6407/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240403/1a2f6407/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240403/1a2f6407/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240403/1a2f6407/attachment-0005.png>
More information about the QGIS-User
