[Qgis-user] Plugin using Pythonnet fails to start during installation
Lars I. Nielsen
lin at LIFA.DK
Thu Apr 4 05:27:43 PDT 2024
Hi all.
We've developed a QGIS plugin, that utilizes Pythonnet to communicate with C# on Windows.
Pythonnet is not part of the chosen distribution for Python in QGIS (as of 3.34), so we do a separate installation of this module into %APPDATA%/Python, which is used by all Python distributions on the PC.
But even after Pythonnet has been installed correctly, we get an error when the QGIS plugin installer tries to start the plugin.
[cid:image003.png at 01DA869B.F8C7D6B0]
However, the plugin has been installed correctly, and it starts just fine when one manually activates it in the plugin window list.
Why can't the plugin start when activated by the QGIS plugin installer ?
Is it running in some kind of restricted environment, that excludes use of the APPDATA location ?
Cheers.
Ps!
Yes, we are aware of different versions of Pythonnet in Python 3.7 vs 3.9. We install both.
Med venlig hilsen
Lars I. Nielsen
GIS-kons., FME+Python Certified Professional
GeoData
[cid:image001.png at 01DA869A.F5B33920]
Dir.
+4563136849<tel:+4563136849>
Tlf.
+4563136800<tel:+4563136800>
Mail
+lin at lifa.dk<mailto:lin at lifa.dk>
LIFA A/S · Tlf +4563136800<tel:+4563136800> · lifa.dk<https://www.lifa.dk/> · CVR 20937289
Odense · Fredericia · Glostrup · Hillerød · Kerteminde · Kolding · Middelfart · Vejle · Vissenbjerg · Aarhus
[cid:image002.png at 01DA869A.F5B33920]<https://www.linkedin.com/company/lifa-a-s/>
Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/7ac7f240/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/7ac7f240/attachment-0003.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/7ac7f240/attachment-0004.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/7ac7f240/attachment-0005.png>
More information about the QGIS-User
