[Qgis-user] Moving many project files - bulk updating paths to tables?
Antonio Viscomi
antoviscomi at gmail.com
Fri Apr 5 01:15:58 PDT 2024
Hi Tony,
if you're using linux what you need is simply use the 'sed' command by
terminal as i.e.:
*sudo sed -i 's/NEWPATHTOSUBSTITUTE(your path or IP or domain)/OLDPATH/g'
*.qgs*
Cheers
Antonio
Il giorno ven 5 apr 2024 alle ore 09:58 Gordon Wakelin-King via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> There is a project packager plugin that works pretty well. It may not be
> exactly what you need but maybe the author could be approached for tips on
> the process.
> Get Outlook for Android <https://aka.ms/AAb9ysg>
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> on behalf of Tony
> Shepherd (FarmMaps NZ) via QGIS-User <qgis-user at lists.osgeo.org>
> *Sent:* Friday, April 5, 2024 6:06:48 AM
> *To:* 'Jorge Gustavo Rocha' <jgr at geomaster.pt>; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Moving many project files - bulk updating
> paths to tables?
> Thanks Jorge
> Yes, I toyed with that, but somewhat painful with thousands to process.
> Has anybody scripted or coded something for this?
> Cheers
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Jorge
> Gustavo Rocha via QGIS-User
> *Sent:* Friday, April 5, 2024 7:53 AM
> *To:* qgis-user at lists.osgeo.org
> paths to tables?
> Hi Tony,
> You can unzip the qgz file and change the text in the qgs files. qgs are
> text files. Afterwards, you can create the zip again with the qgz extension
> or open the qgs file directly.
> I hope it helps,
> Jorge
> On 04/04/24 19:28, Tony Shepherd (FarmMaps NZ) via QGIS-User wrote:
> Hi All
> I am sure I am not the first to ponder how to deal with this. I have
> loads, thousands likely, of project files in a series of folders and
> subfolders. I need to move those files and folders to a new location to
> enable other staff to use the project files and their associated shp files,
> geo packages, rasters etc.
> Essentially, I am shifting my entire collection of GIS work to a shared
> location for others to start using, so moving from a sole operator to a
> shared environment.
> In my old MapInfo days, I would simply do a bulk search and replace over
> the workspace files (text-based so this is easy) and change the paths that
> need changing and all would be ok.
> As qgz files are not easily modified through a text editor, are there any
> tools out there to enable bulk changing of file paths in those files?
> Any other approaches?
> Cheers
> Tony
> *Tony Shepherd*
> * GeoSpatial Manager @ FarmMaps NZ & Photographer @ Shepherd Photos*
> *Phone* *–* 027 435 6193 | *Website – *shepherdphotos.co.nz
> *Email** – Maps* tony at farmmaps.nz | *Email – Photos*
> tony at shepherdphotos.co.nz
> *Facebook* TonyShepherdPhotos
> <https://www.facebook.com/TonyShepherdPhotos>
> [image: FM_logo1_small (Custom)]
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240405/be8093a5/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240405/be8093a5/attachment.jpg>
More information about the QGIS-User
