[Qgis-user] geojson
Alexei Schwab
alexei at fastmail.net
Wed Apr 10 00:09:28 PDT 2024
Hi Manuel,
You can change the position of the label in the layer label settings: https://docs.qgis.org/3.34/en/docs/user_manual/style_library/label_settings.html#placement-for-line-layers
Under the Placement tab > General settings section, you can change the text position from Above line to On line.
You might want to add a buffer or backgroiund to the text to keep it legible over the line.
Regards,
Alexei
On Tue, 9 Apr 2024, at 15:50, Manuel Fernandez via QGIS-User wrote:
> I have a streets layer in geojson. Is it possible to put the name tag on the line? Not in a popup.
> Thanks a lot
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240410/56a7a057/attachment.htm>
More information about the QGIS-User
