[Qgis-user] geojson
Alexei Schwab
alexei at fastmail.net
Wed Apr 10 00:53:57 PDT 2024
Hi Manuel,
Can you give some more info about your data and how you are trying to use it? If you can share a link to a copy or sample of the data, even better.
>From your sample it looks like you're maybe trying to make a webmap - where does QGIS fit in? Are you using the qgis2web plugin?
The more info you can share about your data and workflow the more likely it is someone will be able to help.
Regards,
Alexei
On Wed, 10 Apr 2024, at 08:27, Manuel Fernandez wrote:
> Hello Alexei.
> My problem is that I can't put the street name tag. My file is a geojson. And the field es name. I have trid :
> var totcmnosLayer = L.geoJson(null);
> $.getJSON("data/tot_cmnos.geojson", function(data){
> totcmnosLayer.addData(data);
> onEachFeature: function(feature, layer) {
> if (feature.properties && feature.properties.DENOMINACI1) {
> layer.bindPopup(feature.properties.DENOMINACI1);
> or layer.bindLabel, bindTooltip
> But I doesn't work. :(
> Thanks a lot
> El mié, 10 abr 2024 a las 9:16, Alexei Schwab via QGIS-User (<qgis-user at lists.osgeo.org>) escribió:
>> __
>> Hi Manuel,
>> You can change the position of the label in the layer label settings: https://docs.qgis.org/3.34/en/docs/user_manual/style_library/label_settings.html#placement-for-line-layers
>> Under the Placement tab > General settings section, you can change the text position from Above line to On line.
>> You might want to add a buffer or backgroiund to the text to keep it legible over the line.
>> Regards,
>> Alexei
>> On Tue, 9 Apr 2024, at 15:50, Manuel Fernandez via QGIS-User wrote:
>>> I have a streets layer in geojson. Is it possible to put the name tag on the line? Not in a popup.
>>> Thanks a lot
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240410/90372bac/attachment.htm>
More information about the QGIS-User
