[Qgis-user] QGIS-User Digest, Vol 218, Issue 10 Moving many project files - bulk updating
Reginald Carlier
Reginald.Carlier at ingelmunster.be
Thu Apr 11 05:41:01 PDT 2024
Just reading about a script to bulk change qgz and other files.
A couple of years ago I needed this functionality when the servernames changed, so I wrote this script:
import os
import zipfile
import ntpath
# Wijzig deze map zonodig
startdir = "C:/"
newserver = "somenewserver"
oldserver = "10.195.6.122"
oldserver2 = "10.195.5.110"
oldserver3 = "10.195.5.101"
def path_leaf(path):
head, tail = ntpath.split(path)
return tail or ntpath.basename(head)
def replace_servername(fl, svname):
print("opening file " + fl)
f = open(fl,'r')
filedata = f.read()
f.close()
newdata = filedata.replace(oldserver,newserver)
data2 = newdata.replace(oldserver2,newserver)
data = data2.replace(oldserver3,newserver)
f = open(fl,'w')
f.write(data)
f.close()
def change_servername(fname, zonder_ext, ext):
if ext == '.qlr':
replace_servername(fname, newserver)
if ext == '.qgz':
with zipfile.ZipFile(fname, 'r') as zip_ref:
zip_ref.extractall(os.path.dirname(fname))
qgsfile = zonder_ext + '.qgs'
qgdfile = zonder_ext + '.qgd'
replace_servername(qgsfile, newserver)
os.remove(fname)
zipObj = zipfile.ZipFile(fname, 'w')
zipObj.write(qgsfile)
if os.path.isfile(qgdfile):
zipObj.write(qgdfile)
os.remove(qgdfile)
zipObj.close()
os.remove(qgsfile)
for (root, dirs, files) in os.walk(startdir, topdown=True):
if files:
for f in files:
fl = os.path.join(root, f)
zonder, extension = os.path.splitext(fl)
if extension == '.qgz' or extension == '.qlr':
change_servername(fl, zonder, extension)
print("klaar")
Reginald Carlier
Deskundige GIS
Gemeente Ingelmunster, Oostrozebekestraat 4, 8770 Ingelmunster
T+32 51 33 74 39www.ingelmunster.be
0207.485.473 (gemeente) - 0212.221.845 (OCMW)
RPR Rechtbank van eerste aanleg West-Vlaanderen afdeling Kortrijk
Wij werken enkel op afspraak
Schrijf je in op onze nieuwsbrief!
Raadpleeg onze disclaimer
-----Oorspronkelijk bericht-----
Van: QGIS-User <qgis-user-bounces at lists.osgeo.org> Namens qgis-user-request at lists.osgeo.org
Verzonden: vrijdag 5 april 2024 9:58
Aan: qgis-user at lists.osgeo.org
Onderwerp: QGIS-User Digest, Vol 218, Issue 10
Send QGIS-User mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of QGIS-User digest..."
Today's Topics:
1. Re: Moving many project files - bulk updating paths to
tables? (Tony Shepherd (FarmMaps NZ))
2. Re: Announce - migrate our mailing lists to Discourse
(DancesWithCars)
3. Re: Announce - migrate our mailing lists to Discourse
(Michael Shand)
4. Re: Announce - migrate our mailing lists to Discourse
(David Strip)
5. Re: Moving many project files - bulk updating paths to
tables? (Gordon Wakelin-King)
Message: 1
Date: Fri, 5 Apr 2024 08:06:48 +1300
From: "Tony Shepherd \(FarmMaps NZ\)" <tony at farmmaps.nz>
To: "'Jorge Gustavo Rocha'" <jgr at geomaster.pt>,
<qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Moving many project files - bulk updating
paths to tables?
Message-ID: <004301da86c3$41fb3da0$c5f1b8e0$@farmmaps.nz>
Content-Type: text/plain; charset="utf-8"
Thanks Jorge
Yes, I toyed with that, but somewhat painful with thousands to process.
Has anybody scripted or coded something for this?
Cheers
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Jorge Gustavo Rocha via QGIS-User
Sent: Friday, April 5, 2024 7:53 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Moving many project files - bulk updating paths to tables?
Hi Tony,
You can unzip the qgz file and change the text in the qgs files. qgs are text files. Afterwards, you can create the zip again with the qgz extension or open the qgs file directly.
I hope it helps,
Jorge
On 04/04/24 19:28, Tony Shepherd (FarmMaps NZ) via QGIS-User wrote:
Hi All
I am sure I am not the first to ponder how to deal with this. I have loads, thousands likely, of project files in a series of folders and subfolders. I need to move those files and folders to a new location to enable other staff to use the project files and their associated shp files, geo packages, rasters etc.
Essentially, I am shifting my entire collection of GIS work to a shared location for others to start using, so moving from a sole operator to a shared environment.
In my old MapInfo days, I would simply do a bulk search and replace over the workspace files (text-based so this is easy) and change the paths that need changing and all would be ok.
As qgz files are not easily modified through a text editor, are there any tools out there to enable bulk changing of file paths in those files?
Any other approaches?
Cheers
Tony
Tony Shepherd
GeoSpatial Manager @ FarmMaps NZ & Photographer @ Shepherd Photos
Phone ? 027 435 6193 | Website ? <http://shepherdphotos.co.nz/> shepherdphotos.co.nz
Email ? Maps <mailto:tony at farmmaps.nz> tony at farmmaps.nz | Email ? Photos <mailto:tony at shepherdphotos.co.nz> tony at shepherdphotos.co.nz
Facebook <https://www.facebook.com/TonyShepherdPhotos> TonyShepherdPhotos
QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240405/e1ecbd4f/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240405/e1ecbd4f/attachment-0001.jpg>
Message: 2
Date: Thu, 4 Apr 2024 16:17:38 -0400
To: chris hermansen <clhermansen at gmail.com>
Cc: R?gis Haubourg <regis.haubourg at gmail.com>, qgis-psc
<qgis-psc at lists.osgeo.org>, qgis-developer at lists.osgeo.org,
Subject: Re: [Qgis-user] Announce - migrate our mailing lists to
Discourse
Message-ID:
<CA+zqz3V2B-pciLiog2H=RpaWJ7yeWqmQooFJ=gFUK9POsQ=BTQ at mail.gmail.com>
I won't be making the transition.
Bye
On Thu, Apr 4, 2024, 14:06 chris hermansen via QGIS-User < qgis-user at lists.osgeo.org> wrote:
> R?gis and everyone else,
> My apologies; I try not to top post but my response is more an overall
> reaction to your announcement rather than a point by point response.
> I was a member (??) over at opensource.com's Discourse instance until
> RedHat decided to shut down support for opensource.com, so I have some
> experience with that Discourse configuration, also plenty of
> experience with mailing lists. Also familiarity with the Ubuntu
> Forums, Stack Exchange etc.
> In my experience, Discourse "out of the box" doesn't offer any net
> benefit to its users.
> It's quite possible that people interested in, and willing to invest
> time and effort into customizing their usage profile would benefit
> more from Discourse than from a mailing list. I have no experience with that.
> You may be correct when you say that we will attract more new users by
> offering them Discourse than by maintaining a mailing list. I guess
> the question that begs to be asked is, will those new users thereby
> turn into contributors, or will the biggest Discourse channel be "how
> do I install QGIS on my new Mac"?
> I suppose, perhaps wrongly, that most of us on this (and other)
> mailing lists are here because the list provides a sense of community,
> an opportunity to pay back by offering a bit of help, an opportunity
> to stumble on something new and useful from time to time... what else?
> I'm pretty sure none of us participate in this list to learn how to
> participate effectively in lists. Moreover, we don't really have the
> tools to "only pay attention to topics X, Y and Z". So all of us get
> to see the beginner questions, and the responses, and sometimes we
> find ourselves in the situation of starting fresh with something that,
> because of this broad familiarity, is not a total blank.
> In contrast, in my experience, moving to Discourse, or any other
> similar forum-type structure, allows or even encourages us to stick to
> certain topics that we think may be of interest and avoid all others.
> I would argue that we thereby cheapen and diminish our contribution
> back to the forum, simply because we miss real opportunities to help
> while we avoid reading certain topics; and by doing so, we reduce the
> sense of community we get by belonging to the list. I would further
> argue that we run the risk of not learning many new things because by
> streaming topics into tens or hundreds of specialist channels, we
> inevitably miss things that might benefit us.
> Finally, we have the "opportunity" to spend more of our limited time
> learning about configuring our participation in this mechanism, rather
> than just participating. Your example of learning how to treat
> Discourse like a mailing list by following the Mozilla tutorial
> addresses this situation precisely - instead of helping a person with
> their configuration issues, or learning more about how to structure
> the queries used in QGIS, we are tweaking the Discourse knobs and levers to get the "optimum" experience.
> I guess you can tell that I'm negative on this concept. I don't feel
> that the mailing list is a be-all and end-all. But I am pretty sure,
> again based on my experience, that the lovely community we have here
> on qgis-user at lists.osgeo.org will not be the same collection of good
> things once migrated to Discourse. I do hope that I am wrong!
> On Wed, Apr 3, 2024 at 7:04?AM R?gis Haubourg via QGIS-User <
>> [Message sent to all QGIS's lists. Sorry for crossposting - **please
>> reply only in PSC list** ] [stuff deleted]
>> Any thought from you is more than welcome, from ranting against
>> modernity to thanking SAC for their hard work.
> And thank you, SAC, for your hard work!
> Chris Hermansen ? clhermansen "at" gmail "dot" com
> C'est ma fa?on de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/ffe5634d/attachment-0001.htm>
Message: 3
Date: Thu, 4 Apr 2024 20:49:03 +0000
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Discourse
Message-ID: <52c0a0e2-faa6-4fb7-adc6-c2a621d2157d at email.android.com>
Another great mapping list bites the dust.
I used CartoSOC for over 20 years which was great for info and connecting with like minded cartographers, after a merger it became a Forum and died a slow death.
Sent from Samsung mobile
On 4 Apr 2024 21:29, DancesWithCars via QGIS-User <qgis-user at lists.osgeo.org> wrote:
Bye
On Thu, Apr 4, 2024, 14:06 chris hermansen via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
My apologies; I try not to top post but my response is more an overall reaction to your announcement rather than a point by point response.
I was a member (??) over at opensource.com<http://opensource.com/>'s Discourse instance until RedHat decided to shut down support for opensource.com<http://opensource.com/>, so I have some experience with that Discourse configuration, also plenty of experience with mailing lists. Also familiarity with the Ubuntu Forums, Stack Exchange etc.
In my experience, Discourse "out of the box" doesn't offer any net benefit to its users.
It's quite possible that people interested in, and willing to invest time and effort into customizing their usage profile would benefit more from Discourse than from a mailing list. I have no experience with that.
You may be correct when you say that we will attract more new users by offering them Discourse than by maintaining a mailing list. I guess the question that begs to be asked is, will those new users thereby turn into contributors, or will the biggest Discourse channel be "how do I install QGIS on my new Mac"?
I suppose, perhaps wrongly, that most of us on this (and other) mailing lists are here because the list provides a sense of community, an opportunity to pay back by offering a bit of help, an opportunity to stumble on something new and useful from time to time... what else? I'm pretty sure none of us participate in this list to learn how to participate effectively in lists. Moreover, we don't really have the tools to "only pay attention to topics X, Y and Z". So all of us get to see the beginner questions, and the responses, and sometimes we find ourselves in the situation of starting fresh with something that, because of this broad familiarity, is not a total blank.
In contrast, in my experience, moving to Discourse, or any other similar forum-type structure, allows or even encourages us to stick to certain topics that we think may be of interest and avoid all others.
I would argue that we thereby cheapen and diminish our contribution back to the forum, simply because we miss real opportunities to help while we avoid reading certain topics; and by doing so, we reduce the sense of community we get by belonging to the list. I would further argue that we run the risk of not learning many new things because by streaming topics into tens or hundreds of specialist channels, we inevitably miss things that might benefit us.
Finally, we have the "opportunity" to spend more of our limited time learning about configuring our participation in this mechanism, rather than just participating. Your example of learning how to treat Discourse like a mailing list by following the Mozilla tutorial addresses this situation precisely - instead of helping a person with their configuration issues, or learning more about how to structure the queries used in QGIS, we are tweaking the Discourse knobs and levers to get the "optimum" experience.
I guess you can tell that I'm negative on this concept. I don't feel that the mailing list is a be-all and end-all. But I am pretty sure, again based on my experience, that the lovely community we have here on qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> will not be the same collection of good things once migrated to Discourse. I do hope that I am wrong!
On Wed, Apr 3, 2024 at 7:04?AM R?gis Haubourg via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
[Message sent to all QGIS's lists. Sorry for crossposting - **please reply only in PSC list** ]
[stuff deleted]
Any thought from you is more than welcome, from ranting against modernity to thanking SAC for their hard work.
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/c24a2f82/attachment-0001.htm>
Message: 4
Date: Thu, 4 Apr 2024 15:29:24 -0600
Discourse
Message-ID: <c4ae20a2-4056-443f-8a9f-3e7f91f1cd8c at stripfamily.net>
Content-Type: text/plain; charset="us-ascii"
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/019a55df/attachment-0001.htm>
Message: 5
Date: Fri, 5 Apr 2024 07:58:23 +0000
From: Gordon Wakelin-King <gordon at wakelinassociates.com.au>
To: "Tony Shepherd (FarmMaps NZ)" <tony at farmmaps.nz>, 'Jorge Gustavo
Rocha' <jgr at geomaster.pt>, "qgis-user at lists.osgeo.org"
paths to tables?
Message-ID:
<ME2P282MB22422EFEF0BEC9774041F914E4032 at ME2P282MB2242.AUSP282.PROD.OUTLOOK.COM>
Content-Type: text/plain; charset="windows-1252"
There is a project packager plugin that works pretty well. It may not be exactly what you need but maybe the author could be approached for tips on the process.
Get Outlook for Android<https://aka.ms/AAb9ysg> ________________________________
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> on behalf of Tony Shepherd (FarmMaps NZ) via QGIS-User <qgis-user at lists.osgeo.org>
Sent: Friday, April 5, 2024 6:06:48 AM
To: 'Jorge Gustavo Rocha' <jgr at geomaster.pt>; qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Thanks Jorge
Cheers
Hi Tony,
I hope it helps,
Jorge
Hi All
Cheers
Tony
Tony Shepherd
Phone ? 027 435 6193 | Website ? shepherdphotos.co.nz<http://shepherdphotos.co.nz/>
Email ? Maps tony at farmmaps.nz<mailto:tony at farmmaps.nz> | Email ? Photos tony at shepherdphotos.co.nz<mailto:tony at shepherdphotos.co.nz>
Facebook TonyShepherdPhotos<https://www.facebook.com/TonyShepherdPhotos>
[FM_logo1_small (Custom)]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240405/94be66d9/attachment.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240405/94be66d9/attachment.jpg>
Subject: Digest Footer
End of QGIS-User Digest, Vol 218, Issue 10
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240411/cf6aacc6/attachment-0001.htm>
Type: image/png
Desc: image520723.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240411/cf6aacc6/attachment-0004.png>
Type: image/png
Desc: image113227.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240411/cf6aacc6/attachment-0005.png>
Type: image/png
Desc: image757869.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240411/cf6aacc6/attachment-0006.png>
Type: image/png
Desc: image200095.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240411/cf6aacc6/attachment-0007.png>
More information about the QGIS-User
